1 - 13 of 13 Posts
Here is my current setup. The sound is great!
I hate the look.
I would love to make the speakers disappear but not loose much sound quality :D
The wall the TV is on was put up by me it hides a gas meter.
I can do any needed construction.
I'm thinking of putting the in-walls just below the TV.
Any suggestions would be greatly appreciated.
Thanks.
in-wall speakers is always a compromise in sound over standard speakers placed within a room. Usually you loose lower end extension as well as imaging. Placement is also much harder as you cant move them if they dont sound right.
What kind of budget are you looking at? Tony makes some good points, superior in-wall systems are available but usually cost much more than comparable floorstanders or bookshelf speakers.
Triad
James
RBH Sound
all make very good in-walls and I would recommend you start by auditioning those.
What are your current speakers? Picture is too dark to tell.
Discussion Starter #4
I'm not sure. My current ones cot $1,500 for the 3 retail but I got a deal. I would say 1K.
Discussion Starter #6
Thanks for the suggestions. Question. Would the speakers with their own enclosure
have a better sound all things being equal?
The challenge is that the wall will color the sound of the speaker, is it good, maybe but not nessisaraly. In walls with enclosures don't really improve sound just make it work with the type of drivers thay use.
No guarantee on that - that is why they are made both ways.
Discussion Starter #9
Understood. having the wall color the sound is my biggest worry. I don't mind loosing some SQ. for the
improved aesthetics but I dont want to have the entire wall become a speaker.
I have to question the design, duel tweeters and duel drivers would seem to me cause issues with how it produces sound. I may be wrong but I'm suspicious.
Anyone ever heard these?
http://www.proacousticsusa.com/productdetail.php?pId=2473
I would stick with an established name brand speaker company
Also, a good speaker designer/company will know how to work
around some limitations. >> It is not like in-wall speakers were
just created with-in the last couple of years.
I would also stick with one tweeter per baffle.
Your call
Discussion Starter #13
I'm going to bag the in wall idea. Even my dealer tells me I'm going to loose a lot.
He says I can get close but would have to spend quite a bit more.
I'll work on getting things setup better. I'll get the cables moved lower and look for better stands or
spikes for the bookshelves speakers.
When I replaced the tv from 42" to 60" I had to lower the speakers and never moved the wires lower.
Thanks for all the input.
1 - 13 of 13 Posts
