1 - 5 of 5 Posts
My AM/FM Rotel receiver is in the basement,and the FM reception is mediocre at best.Any reasonable recommendations for a decent indoor antenna?I currently have one of those "T" wire ones that comes with the component.
I would rather not have to run a coax cable outside?
Thanks:sn:
I have an outdoor antenna in my attic: great digital reception and decent fm reception. For indoor antennas, I believe Terk used to make some of the better amplified devices, probably $50-150, depending on model. For quick check, Crutchfield carries a large selection...this one looks decent since you do receive signals.
Thanks Ironglen..........I think RadioShack sells them?
Is there a certain input/type of cable in the back of the Rotel AM/FM Receiver or is it standard?
:sn:
1 - 5 of 5 Posts
