1 - 5 of 5 Posts
does anyone know the actul high end fq rolloff is on the Rockford Fosgate P2D4-10
does it really only go up to 250hz
when i put this into Winisd the fq curve seemed to drop off around 1500hz at -3db
i need to know for sure as i plan to use in a 3 way floorstander build an i want to crossover at 500hz for the lows
according to winisd i can pump 220watts into it with it wired a 2 ohms
an get a very nice response
any thoughts or advice is welcome
thanks
im having a custom crossover buil by Bill Daniels at dstechlabs
an im tring to decide which is better for the budget
the slightly cheaper p2d4-10
or for a little more
the Dayton Audio RSS265HO-44 10" Reference HO DVC Subwoofer
cab designs
174312
174313
174314
174315
174316
174317
Greets!
WinIsd doesn't account for the driver's inductance, so with 5.3 mH its HF response is already down nearly 4 dB/250 Hz and nearly 11 dB/500 Hz whereas if it had the RSS265HO-44's 0.77 mH it would still be nominally flat out to 500 Hz, so combined with its little bit stronger motor it's a much better choice.
Really need to use Hornresp or other software that accounts for inductance.
GM
thanks for that ,the exsplains a lot
inv tried that hornresp but have no idea how to work it
could you check out the Skar Audio VD-10 D4 for me it reads the same way in winisd out to 1000hz at - 1db
can you tell me how it reads or is winisd reading it right
Already asked and answered!
The Skar has no Le spec, so assumes flat impedance, hence sims the same plus must assume it's high, implying a cheaply designed motor same as the 'Punch' sub woofer, so probably won't be usable to 500 Hz.
GM
1 - 5 of 5 Posts
