1 - 3 of 3 Posts
Hello to all!
When usin Umik-1 with REW, last beta version, got the following error:
Can anyone help?
I am using Linn Songcast as a "virtual" sound card; works fine in the previous version of REW.
Input device error
javax.sound.sampled.LineUnavailableException: Microphone (Umik-1 Gain: 12dB ) does not have any lines supporting PCM_SIGNED 48000.0 Hz, 16 bit, stereo, 4 bytes/frame, little-endian
Level:
SEVERE
Stack Trace:
roomeqwizard.CC.T(Unknown Source)
roomeqwizard.Q$4.actionPerformed(Unknown Source)
javax.swing.JComboBox.fireActionEvent(Unknown Source)
javax.swing.JComboBox.setSelectedItem(Unknown Source)
roomeqwizard.CC$3.run(Unknown Source)
java.awt.event.InvocationEvent.dispatch(Unknown Source)
java.awt.EventQueue.dispatchEventImpl(Unknown Source)
java.awt.EventQueue.access$200(Unknown Source)
java.awt.EventQueue$3.run(Unknown Source)
java.security.AccessController.doPrivileged(Native Method)
java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
java.awt.EventQueue.dispatchEvent(Unknown Source)
java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
java.awt.EventDispatchThread.pumpEvents(Unknown Source)
java.awt.EventDispatchThread.run(Unknown Source)
Could be some other driver (the songcast?) has taken exclusive control of the UMIK so Java is not being given any access. Check the Windows recording properties for the UMIK input and try unticking the box on the Advanced tab that allows applications to take exclusive control.
Thank you, indeed that was the problem...
Now I can measure with REW...I just arrived an another problem, but that is I guess related with the audio card...
1 - 3 of 3 Posts
