1 - 3 of 3 Posts
Hi all
First post here.
Have run up REW and got it all working - the help files are way better than most!
I've produced an IR and exported the .wav file - and exported the measurements to a .txt file as well and the results are what they should be for my room/speakers.
Is it possible in REW or using another piece of software to invert the IR. The reason for this is to overlay it into Foobar via the Convolver plugin, that is it should do some DRC. I currently use the Behringer DEQ 2496 but this should be far more accurate.
Any help or suggestions much appreciated.
Jim
1 - 3 of 3 Posts
