I was thinking about doing the same thing. I have tested remote jr on my iphone remotejr and it looks promising.
I was also looking to combine with this [cut]redeye-mini-converts-iphone-ipad-or-ipod-touch-into-ir-beaming
Although It doesn't look like its available anywhere yet. Hopefully it will be out soon as I would want to control TV,Cable, HTPC (Windows 7), AMP. Although if this isnt available I will look at other options.
I am on vacation at the moment but will be looking to pickup an ipad when I get back to Chicago.
Thanks
I bought last week a RedEye mini (£52 shipping incl.) and it comes with a nice keychain holder.
I have both an iphone and an ipad. The software is only for the iphone (it can be used on the ipad as well but it has to be used using the 2x button).
I have a logitech harmony one remote and I'm very happy with it but I was looking for something more customizable. With the redeye software is very simple to use and you can add as many devices as you want (even if there are no codes for my infocus projector and air conditioner).
Pros:
- lightweight with a nice keychain holder
- product support is quick. I sent an email regarding the missing codes and they replied me back in 3 hours (they told they already asked for those codes)
- software very intuitive
- accelerometer gesture commands
- no battery
Cons:
- the delay (ca 1 second) of the commands sent. With the logitech they are sent immediately.
- codes database lacks of some devices.
- no "hd" software for the ipad.
I think all the cons could be sorted out in the next software updgrade. If the delay issue will be fixed soon I'm very happy to put my logitech in the drawer
Cheers.
