1 - 3 of 3 Posts
Everything else being the same, I get different readouts when I test with ASIO and Java. They're not TOTALLY different but its quite significant at certain freq. I dont know the nuts n bolts of Java or ASIO....is this normal??
I'll try posting pics in a bit.
> It's not normal .
> Results like that, would infer ( to me ) that you should review the basics of getting REW to work properly with your soundcard .
:sn:
Lol I figured it out....my ASIO out on my EMU card has an eq on it, the WAV out (which Java uses) didnt :p
Thanks though!!
1 - 3 of 3 Posts
