Define "worth." Nobody can decide that but you. I can tell you this, movie theaters would have ZERO projectors in them today if they could get a bright LED direct-view screen at an attractive price. Projection cannot even remotely reveal how much better HDR is than SDR AND with the light output so limited compared to LED/LCD TVs and to OLED TVs. Projection is dying and as soon as it can be replaced in theaters economically, projectors will disappear from cinemas. Only direct-view LED screens can provide the luminance required to produce the larger color space supported by UHD/HDR. And you really need to have the display output 1000 nits or more for peak white for HDR to look impressive. A 2000 lumen projector won't even get you to 200 nits. Consumer flat panel TVs can produce 600 nits to 3000 nits or even a little more than 3000 nits in some newer models. In a movie theater, the projector can't typically deliver more than about 75 nits. If you try to make projection as bright as bright flat panel TVs, all the extra light reflects into the room and back onto the screen making shadows and blacks look milky and distracting. I have a fairly bright laser-phosphor projector that sells for 5-figures. I don't even turn it on anymore after seeing how much better an 85-inch 4K TV capable of 3000 nits looks compared to that projector. Some people are so hung up on having a 10-foot wide screen, they ignore all the presentation quality lost during projected video vs. flat-screen video. For them, nothing matters more than having a big image. You can have the same viewing experience sitting 8 feet from an 85-inch diagonal flat screen TV and an 11-12 foot viewing distance of a 120-inch wide screen. In both setups, the screen will appear to be the same size. Summarizing: circa $3000 for an 85-inch LED/LCD flat panel TV versus $26,000 laser phosphor projector and the $3000 TV wins by a landslide. $3000 TV with 3000 nits peak white versus projector with 1.3 gain screen and 200 nit projector and the flat screen TV wins easily.
