1 - 15 of 15 Posts
All,
I am creating a home theater as part of finishing my 1900 square foot basement. I have been shopping for the right system for some time and believe I have landed on the most bang for my buck. I would like your opinion as it will help to shape mine. First, a few factoids:
1. My budget for speakers (JUST speakers) is $4000.
2. I will be using my home theater as follows: 80% movies, 15% gaming, 5% music
3. The biggest challenge with my basement is the open floor plan (see attached). Any acoustical tips are appreciated.
And the equipment is...
FR, FL - Paradigm SE 3
Center - Paradigm SE Center
Subs (2) - Paradigm SE Sub
In-ceiling surrounds (4) - Paradigm Designer Series: AMS-150R-SM
Total cost from dealer: $3269.00
Other decisions already made
1. Oppo BDP-103
2. Denon AVR-X4000
3. Panasonic TCP65ST60 65" plasma
Thanks eveyrbody!!!!!
Dougc,
Thanks for the response. I have heard it both ways: put the subs on opposing walls, put the subs in the corners. Does anyone else have a thought on this?
~MLGamer
Well, like it was stated the sub placement can differ room to room. Really depends on the floor plan and acoustics of the room. I know in my room i put the subs in the back two corners. Then I later moved them toward the front about halfway toward the front on the side walls. In the end I wired the front and put them on each side of the center channel. And there I have really noticed the differance and increase of LFE.
Maybe wire the sides and Front so you have flexability later. That is if you dont have the ability to test it out before the walls are closed up.
What are you planning to do in the back of the room to seperate the theater with the rest of the basement?
Walling it off or some other type of seperation like heavy curtains?
The dimensions of the theater room area may help others give ideas for a way to seperate the room off. HxWxD
Dougc,
~MLGamer
Having just one sub in my setup I found placed next to the wall close to my two main listening positions worked best. I have a living room setup so my options were a bit limited but nearfield works quite well.
Placing the subs in the corners will often increase the sound by several db, sometimes too many. I did some experimenting with my subs last night as I am also planning a remodel and build for my new subs. I didn't meter my results, but there is a very large increase in LFE when I moved one of the subs to each of the corners of the room. I left the other one front center where it has always been while my son switched the signal from the stationary sub in the middle as I rolled the other sub around the room to find the "sweet" spot.
In regard to having the sub next to you, near-field, I tried this as well. I discovered a loss of LFE when I put the sub next to my listening position, or about 4" from the couch pointing at the couch. What I liked about this position is that I could "feel" the sub the most there - A LOT more.
That looks like a great plan..Ever think about a projector?..Your front wall looks like a great candidate for a nice 120" screen :) and, for the same price of that plasma, you could get a very nice projector and screen :T
My wife wants to keep the space between the billiards room and the home theater open. The dimensions of the theater room are 19' 9" x 21' 7"; however, if you take into consideration the open area to the billiards room, the dimensions expand to approximately 37' x 21'.
Thanks,
MLGamer
Two questions from the new guy: what is "LFE" and what is "near-field"?
~MLGamer
Hello,
My ceilings are only 8' high. Is the idea of a projector feasible? Also, I am all about picture quality. Will the return on investment provide me with similar or better picture quality?
Thanks,
MLGamer
Discussion Starter · #14 ·
All,
I appreciate all the replies regarding sub placement. This is a very important topic for consideration; That being said, the original question was regarding the equipment I am considering with the following parameters:
Read more: http://www.hometheatershack.com/for...ystem-expert-advice-please.html#ixzz2b7GwnmKh
My ceiling is only 8' high as well and my 100" screen is looking small now :bigsmile:
Excellent picture can be easily obtained with a nice projector and screen combo, for less then the plasma you are looking at..and, where you sitting, a 1080p projector would look amazing!!
Check these out..
1080p 2D and 3D projector--
http://www.amazon.com/Epson-PowerLi...id=1375735647&sr=1-28&keywords=1080+projector
120" fixed screen--
http://www.amazon.com/Elite-Screens...8&qid=1375735186&sr=8-1&keywords=fixed+screen
Total cost for a 120" screen and projector with 3D capabilites= $2,100
Of course there are better projectors for a couple more bucks, but this a great combo, I'm sure you would be very pleased with
1 - 15 of 15 Posts
