1 - 2 of 2 Posts
Hi guys,
I'm hoping someone here has experience with this equalizer. I'm have the equalizer located between my pre amp and amp in my system, and I cannot seem to get the LED meter (the two channel bouncing lights) to illuminate past the first light regardless of the volume of the system. Even when turned up to almost intolerably loud levels, the lights don't indicate increased db level. I've tried adjusting (pressing) the "MAX switch" on the rear panel, which I understand is for lower gain pre amps, and nothing meaningful happens. Thanks for the help! Hopefully I'm not the only one with this specific issue.
Edited to articulate that the issue is not simply that I want to see more lights but that when I adjust the volume even slightly on my pre amp when the Ultracurve Pro deq2496 is in the system the volume is either unbearably loud or inaudibly soft. Thanks again.
1 - 2 of 2 Posts
