1 - 8 of 8 Posts
Newbie alert should go off. :)
Do i still need a BFD now that i have my Onkyo with audyssey and whatnot..
regards
Mads
Adding an eq might be overkill but it depends on your goals. :bigsmile:
Is the system going into a dedicated room or a living room?
Matt
Its for a dedicated Cinema.. with concrete floor and walls. a couple of small rugs,.
When using the onkyo for eq i think im missing some of the 'middlebass area'
so i was kind of wondering if a BFD would help out here.. its not that expensive.
you should do a rew sweep and post it. Before running aud and after run aud preferably.
You may have a null that you are missing... i had a similar issue and i was able to resolve it by placement/phase/bfd.
I intend to this weekend if not sooner.. only thing is.. i only have the old RS spl meter. i hope it will do allright..
thanks..
1 - 8 of 8 Posts
