1 - 3 of 3 Posts
Hi,
today i started the room eq wizard and i get a java error #52. I tryed to uninstall, same error, i tryed to install a new version, same error... Newest java is already installed. Have windows 7 64 Bit installed. Anyone a idea ?!
Which version ( build # ) of Java 7 do have on your computer ?
- I'll assume you're not trying to use the latest REW 5.01, beta 21 with Java 6 ( since it must use Java 7 ) .
So ;
- Try installing Java 6 ( & disengage Java 7 from within the Java control panel ) .
Java 6 download page
Once you have Java 6 working ( & Java 7 disengaged ) you should be able to uninstall your older REW version .
If successful ( in uninstalling REW ) then download & install the latest REW version ( after re-engaging Java 7 & disengaging Java 6 ) .
:sn:
1 - 3 of 3 Posts
