1 - 4 of 4 Posts
Hi Folks,
I just went to download REW to analyze my theater and realized that I will need to download Java onto my PC. In the past, I have purged my PC of all things Java due to security concerns. Is it possible to use REW without Java? If not, my plan is to only enable it when I am offline and doing tests and then disable it when I am back on line. How are others addressing this if at all?
Mike
Bear in mind there is a distinction between the Java that lives on your computer for local applications to run (which REW uses on Windows) and having Java accessible in your browser, where malicious code may try to exploit it. Disabling Java in the browser won't affect REW.
1 - 4 of 4 Posts
