1 - 5 of 5 Posts
Hi does anyone know if these units came with an inbuilt high pass filter and if so what is the frequency they set the cut off at?
I am building a Passive radiator based on Adrian Macks 12"XLS peerless design. I have the peerless driver but substituted the Peerless Passives with 2 12" scanspeak passives.
The winisd program showed that I really should have a high pass filter (aka subsonic filter)
as Driver excursion will be exceeded very quickly below the 16Hz range.
Is there off the shelf options for this? I have searched and search and keep coming up with DIY circuits which I oculd probably have a crack at. But I am unsure how to fit this circuit into my system line then.
If anyone is able to point me in the right direction would be great.
thanks
Alex
Super Moderator
What is the amp, a "Jaycar 300W"? Almost all sub plate amps have built in HPFs, though you'd need to know the specifics of your exact amp to be sure.
the amp is model AA0508 350wrms 4/8ohm plate amplifier. I bought it at Jaycar quite some years back. They no longer sell them. I tried ringing the technical help department in case someone there still has data on them but no one has returned my call.
Discussion Starter #4
Please be gentle with my total noobiness with all things electrical here I am trying to complete my project but at the same time I am also interested to learn and gain better understanding of what's happening as best i can.
I plugged all my data into WinISD. my main concern is when watching movies if there is a very low frequency signal as I understand some blurays go down to single figure Hz. According to winisd anything below 16Hz will be well over my safe limit for driver exertion.
So I added a high-pass filter to the winisd project and it adjusts the curve nicely showing that my driver wont over exert.
The setting for the HPF in winisd were: 3rd order cut-off 16Hz Q0.707 Butterworth. (if i had it set to 2nd order or 1st order the curve was still in the danger zone of exertion for the driver.)
How do I now translate this information into a circuit to be built? What further information do I need?
Once the circuit is built how do I integrate it to my system?
Discussion Starter #5
well i took the amp to work and had a guy check it out with a signal generator and the o-scope under load. so for the record the old Jaycar AA0508 350Wrms amp does have a second order high pass filter built in. So I have no worries of blowing my driver. according to the circuit diagram it should be kicking in around 28hz but on test it was i think -6db at 20hz and then down at 15hz had dropped off a lot more very safe level to operate teh subwoofer.
1 - 5 of 5 Posts
