Ladies & Gentlemen,
I was building a set of tower speakers with a 2446j & a 2206. I was in the final stages and ready to construct. Then, I came across some literature about the new JBL D2 compression drivers and had to have them. I bought a set of the D2's and decided I wanted the new directional drive neo transducers to go long with them.
My question is, would some one be so kind to run the 2262h for a ported enclosure through the software. I would like to use a square port in a 2sqft box. What would the port dimensions be and what would the tune be?
I have attached the Theile parameters below:
MODEL FS QTS QMS QES VAS EFF PE XMAX RE LE SD BL MMS FLUX
2262H 56.8 0.34 2.79 0.39 49.2 2.2 700 8 5.2 0.0547 18.0 68 392
P.S. If anyone is interested in a set of 2446j's & 2206's with 2380A horns msg me.
