1 - 12 of 12 Posts
Looking to build two sealed subs hopefully using the jbl 1502D wired as 4 ohms, suitable pro audio amp and a behringer fbq2496.
Has anyone tried these subs before in home use? I've got the 1202D in my car and its really good for the money.
This is all the info I could find. 50/50 music/ht.
thanks.
THIELE-SMALL PARAMETERS
VOICE COIL DC RESISTANCE: REVC (OHMS) . . . . . ... 0.96
VOICE COIL INDUCTANCE @ 1 KHZ: LEVC (MH) ... . . . 0.50
DRIVER RADIATING AREA: SD (IN2) . . . . . . ......... .132.53
SD (M2) . . . . . . . .............................................855.00
MOTOR FORCE FACTOR: BL (TM) . . . . . . . ............... 8.20
COMPLIANCE VOLUME: VAS (FT3) . . . . . . . .............. 6.04
VAS (LITERS) . . . . .............................................171.00
SUSPENSION COMPLIANCE: CMS (μM/N) . . . . ..........164.70
MOVING MASS, AIR LOAD: MMS (GRAMS). . . . ..........246.90
MOVING MASS, DIAPHRAGM: MMD (GRAMS) . . ......... 232.50
FREE-AIR RESONANCE: FS (HZ) . . . . . . . ................. 25.00
MECHANICAL Q: QMS . . . . . . . . . . .......................... 6.08
ELECTRICAL Q: QES . . . . . . . . . . ............................ 0.55
TOTAL Q: QTS . . . . . . . . . . . ................................. 0.51
MAGNETIC-GAP HEIGHT: HAG (IN) . . . . . ................. . . 3/8
HAG (MM) . . . . . . . ............................................... 9.00
VOICE-COIL HEIGHT: HVC (IN) . . . . . . . .................. . 1.00
HVC (MM) . . . . . . . . . . ...........................................26
MAXIMUM EXCURSION: XMAX (IN) . . . . . ................. . 5/16
XMAX (MM) . . . . . . . ...............................................8.50
just looking at the new 1514, the xmax rating is nearly double which I take it is the the movement in the cone?
If it's double the Xmax it would make a huge improvement.
The 1502D would distort badly when pushed then?
Not if you keep it within its limits.
No, both slot and round need to be a certain size and length to get a specific tuning. For your sub in 6 cu.ft tuned to 23 hz, a 4 inch diameter round port would need to be 7.75 inches long. A slot port 3" x 4" would need to be 7.25 inches long to do the same thing. Remember that the thickness of the cabinet wall counts for 3/4 of an inch of the length of the port.
Quite a bit more to this than i thought, will have to think it through.
The Velodyne CHT-12Q is £524 over here, is this a better choice than spending time, money and then being very dissapointed with the results?
I've got a Mordaunt short 409w at the mo but want more control over what its doing and better bass.
Thanks
1 - 12 of 12 Posts
