Nobody???:sad:
The MPC 200T amp is high passed at 50hz. The MPC 200 goes down to 20 hz. Which model did you get?I found out that it is high passed at 50hz and was wondering if it would be able to be adjusted down to 20hz
I would like to know the answer to this too :bigsmile: (I just installed my Amp and will tweek this afternoon).... Right now the level in the reciever for my right and left channells are both -10,the lowest it goes, should I set the levels to 0 and then turn down the amp more or is it better to leave the level in the reciever at -10 and turn up the gain on the amp to achieve the correct level. Or does it even matter. It sounds great but I was just wondering if there is a right and wrong way to do it ?????
You set up your gear so you can get the 75db level. If you can't get it with the power amp all the way up, then turn it down so you can. The volume level has to be controled by the preamp.You would think so but if I have my amp gain wide open I can not get the level down to 75db with the master set at 0db. Let me know how you ended up after making your adjustments with your new amp.
Great, Thanks for the info. I thought that would be correct but just wasn't sure.:TYou set up your gear so you can get the 75db level. If you can't get it with the power amp all the way up, then turn it down so you can. The volume level has to be controled by the preamp.
Its like with my Bash sub amps, the receiver's sub out is at -10db, with the Bash volume control only about 1/3. And at that, the sub is about 5~6db hotter than the other channels, which is how I want it.
:sad: .... I didn't have time to play with the toys; I had to cut the grass and do some cleaning on the backyard (I started around 5:00pm and ended arount 8:30pm) ... but I let you know as soon as I do itYou would think so but if I have my amp gain wide open I can not get the level down to 75db with the master set at 0db. Let me know how you ended up after making your adjustments with your new amp.
I just started a new thread to get ideas of what happenend hereYou would think so but if I have my amp gain wide open I can not get the level down to 75db with the master set at 0db. Let me know how you ended up after making your adjustments with your new amp.
:TI just bought another amp today to run my sub. I got a Crown XLS 402d for $185 off ebay. It does 1140w bridged at 4ohms so it should work well with my sub.:yay:
