1 - 8 of 8 Posts
Has any one ever compared two subs;
JL F113 VS SVS PB-13ultra (Seal mode)
I have SVS PB-13 Ultra, and I made it work in a seal mode. it's very tight and home shaking.
I would want to have some more opinions on JL F113 if it's marginally better than SVS or far better?
SVS-PB13 in seal mode is already superb to me.
Do you have room for a second SVS? Two of those should best one of the JL' s, as good as the JL is.
You could also stack dual SVS subs if you don't have the floor space. That would give you anywhere from 3 - 9 dB extra output, depending on your room and sub location.
He has a good point,1 supersub.
Or the 2 very good SVS,i am a big JL fan,butt maybe i go for 2 SVS,more bang for the buck,s .
Are there ne problem,s whit the plate,s.
Ik read a lot about defected plate,s.
Service is great,a new one in a blink of an eye.
So i was wondering or there are much trouble whit the US version of the sledge plate.
Hello,
While I am quite fond of JL's subwoofers, I am quite fond of the 13 Ultra. In addition, I would also consider Rhythmik and the fantastic Seaton Submersive.
Best,
Jack
Do you think JL F212 can outbass 2 of SVS PB-13 Ultra?
Especially with the 13 being a ported enclosure I do not think the Fathom can outdo a dual 13 Ultra setup. Moreover, using dual subwoofers really helps in terms of acoustics. I have been using a Martin Logan Descent i and Depth for about 3 years and when I added the second one it made a huge impact. I have also been blessed to have Audyssey SubEQ HT for the entire duration since using dual subwoofers.
On another forum I came across this link ,against it sheds much light on the test i did for six months whit closed and vented sub,s, the pro,s and con,s. http://www.sonicdesign.se/optimum.html
I heard that with a piece of classic, ported very nice play along while I prefer more for music always closed.
The distinction made ​​what there is between a dynamic and a static alignment alignment. Audiophiles prefer a dynamic alignment (for impulsive bass) but come again deficit static bass (such as organ).
The average listener seems to be preferred. Tuning a static weather E.e.a. is also highly dependent on space.
1 - 8 of 8 Posts
