Hello everybody.
I plan to share with you the construction of my new loudspeakers called 'Jubilo'.
Some time ago, I asked for some advices and opinions, which you can see here:
http://www.hometheatershack.com/for...ice-needed-build-new-3-way-active-system.html
Please forget the cabinet model presented there.
I started the construction of the loudspeakers back in January so in the first posts I will update the construction progress up to is current status. After that you might expect slow updates.
The drivers are:
Tweeter: Seas 27TBFC/G
Mid: 18Sound 6ND430
Woofer: Dayton RS270
The loudspeaker will be made of to separate cabinets. One with to woofers, and another on top in MTM configuration. The cabinets will be placed very closed together, so that the final format will be WWMTM.
Why two cabinets? well, first it will allow to place the mids and tweeters in a less smaller baffle, reducing baffle difraction. Second in the future I will be able to change the cabinets indenpendently of each others.
The crossovers remains the DCX2496. The amplifiers maybe A500 also from behringer. I still don't have one solution for the 6-ch volume controller
