1 - 13 of 13 Posts
G
I have read one of your post about fixing the convergence and I order a stk392-110 and sodered in the ne one and now the tv light comes on but no picture or sound. I checked the resistors and they were all correct but 2 of them. The 2 that were off were marked R863 (150 ohm) and R873 (220 ohm), I tooked them back out and they were the correct ohm but when I put them back in both of them dropped to 89.8 ohm, if I did one at a time they were correct until I put the other in. Can some one help me with this.
Plain ole user
1/150 + 1/220 = 1/89
The resistors are in parallel.
I suggest that you read all of the first 10 posts in the convergence thread. It explains that the -110 should be upgraded, that the resistors should be checked out of circuit, and that it is critical to purchase the parts from a reliable distributor, among much other important information.
If you want specific help, post the model number of the set and specifics about the symptom, diagnostic procedures, and other relevant information about the precise state of the set.
G
I have a JVC av56wp74 and the the first problem was the red convergence would not line up horizontally so I replaced it with a new stk392-110 I should have upgraded to the stk394-160 but thought I should use original parts and when I put it back in tv I didn't have a picture at all. I had a friend that gave me an extra remote awhile back so I call him to see where the tv was and I went and picked it up because it was a JVC av48wp74 so I check the resistor and the readings were the same as mine but I tried that board in my tv it made a clicking noise but no picture. Then I took out some of the resistors out of the48wp74 board and did check the resistors while they were out and were correct but that was when I put them in and they dropped to 89ohm. I did read your other post and I think I put to much compound on the back of stk392-110 and don't have a good ground, could that be it.
Plain ole user
The chips do not get ground from the heat sinks. The reason not to put too much heat sink compound is that it acts like an insulator if there is too much.
If the set worked before, it should work after you put it back together unless you missed a connection or botched the job somehow. You need to be sure that you did not miss something.
It is usually a good assumption to use original parts. Did you buy them from an authorized JVC parts distributor under the JVC part number? If not, and if you did not buy them from one of the handful of reliable distributors of Sanyo STKs, you may have received some bad parts.
G
Thanks for your help, we got my jvc av-56wp74 going like you said if it worked when I took it apart it should work when I put it back together, so just took everything out that I changed and redid it and it started working.
My next question is I tryed the board in the jvc av-48wp74 and it would not let the blue go to the right far enough to align, but it did let me move it left or right and up and down, and the red worked right. Can you help
Plain ole user
Probably a bad output IC and/or open resistor. Read the convergence thread carefully, particularly the first 10 posts.
I am having the same problem, but someone threw my notes away or lost them. can someone tell me the resistor chart. and the two capacitor uf ratings. there are two capacitors that the label has melted. they just metal. no info on them. i am guessing that maybe a 35 volt 220 uf will be ok. but i dont want to take a chance with my new 392-120 ic's
I know this thread is a little old but I have replace the 110's with 150's and I have also read the how to on it as well. checked the resistors and the first one 1.5 ohm 1 watt metal film resistor was out. so I went to my local tv repair shop and picked one up.
the screen turns on and everything works and now all i have to do is set the convergence rightttt?
Unfortunatly whn I go the the convergence menu I cannot go any further and it will not let me go into the auto or manual convergence. There is also a reset button which when I press it the screen goes black but only the green projector light is on.
p.s. have org remote.
any ideas??
thanks
stefan
Plain ole user
I am not really clear on what the problem is. When you say you go to the convergence menu and cannot go any further, what does this mean? Is the green only lit at this point? Do you have the service manual?
that is exactly the problem. when I try to select manual or auto convergence it does NOT go any further. it just sits there for about 10 seconds and then i am able to try and select up and down again. is there some type of secret "secret" to get to the menu. I tried the buttons "ok" and I also tried the vol+ to select it and neither take me anywhere. I am hoping its something stupid. :scratch:
thanks,
Stefan
Plain ole user
I don't recall the service procedures for most sets. I would suggest referring to the service manual for access to adjust the convergence. It likely won't run auto if you have a problem with the alignment at the service level, but again, I do not recall the system on these models.
Verify that you have all of the connections placed securely and properly.
I have a JVC AV65WP74. Originally, the television had a convergence problem. I sent the board off for repair to Startboy1010 on Ebay. He replaced the STK392-110's with STK392-120 IC's. It does not appear that he changed any of the resistors when he did this. After reinstalling the board, the television image was very distorted. See picture 1. It looks like the overall image is wavy.
At this point the magic focus button, and the auto convergence in the menu run, but they don't make any change. The manual convergence feature in the regular menu will not respond.
In the service menu, (I acquired the service menu from startboy1010), it says to turn off the convergence adjustment (f62 from 0 to 1) and then do all of the deflection adjustments manually.
This is the point where I am stuck. I am cannot get the deflection to set normally. The image is badly convex at the top, bottom, left, and right. I cannot seem to adjust it out. It has been suggested to me that there is another problem with the television. However, I can't believe that to be true because before removing the convergence board for repair none of these other symptoms occurred.
Is it typical to have to redo all of the deflection settings and all of the convergence manually once the ic's are replaced on a convergence board? Or should I go back to my original thinking that the repair is no good. Does anyone have the spec sheet for the STK392-120's so I can compare it to the specs for the 392-110 and see if they are identical. I would think that at least some of the resistors should be changed to accomodate differences in the amp design.
Thanks in advance for your help.
Plain ole user
Please read the first ten posts of the convergence repair sticky in the DIY Repair forum VERY carefully.
http://www.hometheatershack.com/for.../5600-crt-based-rptv-convergence-repairs.html
I suggest starting a new thread specific to your problem. You will need to start from the beginning and troubleshoot the problem. I suggest restoring the set to the original state for all settings, read the convergence sticky above very carefully, and test the resistors and power to the ICs. You may have an open fuse in the power supply or you may have an ineffective repair. Hard to tell at this point.
I
1 - 13 of 13 Posts
