1 - 3 of 3 Posts
Not sure if this is the correct place to post. Have a JVC HD-61FN97 Using it for off the air local HD channels and the thing started locking up with a green snow screen. Yellow/Red/White inputs still work. Anyone know of problems with this set? What board do I need to start looking for?
Thanks
Plain ole user
Green snow on what output, HDMI? If so try restarting it and starting your system in a different power on sequence.
I moved your thread to the JVC forum, where it is more likely to get brand specific attention.
The cable input that I hook my HD antenna to. On the tv menu I think it's antenna 1. It use to work fine with a great off air HD picture.
1 - 3 of 3 Posts
