1 - 2 of 2 Posts
I just bought a JVC JLC47BC3002 from Costco and tried to set it up to my satellite system. The tv seemed to work ok but all of a sudden it will have colored distortions own the screen, emit a buzzing sound and turn completely off on it's own. I disconnected everything and tried to connect a blue ray player just using an HDMI cable (that being the only thing now connected to the tv) again, it started up was on a few seconds, same distortion thn the buzz and then it shuts off. Did I get a lemon?:help:
Plain ole user
If you just bought it return it. Check your cables and sources first, but if it happens with more than one source the set is likely defective. Post a picture of the problem.
1 - 2 of 2 Posts
