1 - 5 of 5 Posts
Hi All
My son has broke my screen on my tv (JVC LT-32DA20j ) and have taken out the lcd screen to get the part number but cant see any code number :help: dont need the full box it sits in just the main screen.
Any help would be great
Big thanks
Andy
Plain ole user
You will need to refer to the proper service manual for the part number to order a new one from JVC. The codes on the panel may be useful in finding a used panel from a scrap set. Either way you may need the JVC part number. It is unlikely that it will be cost effective to replace the panel other than used.
As Leonard stated above you may not even have any luck finding a replacement for what it would cost to buy an entire new display. By the time you factor in shipping and the cost of the panel its likely to cost more.
have had a look on ebay and there are a few but not sure if they are right as i dont have a code. see a few sites sell them at what i think is good price. have sent JVC parts an email see what they come up with.
thanks
1 - 5 of 5 Posts
