What you are saying does not make sense. If there is no audio anywhere, you have no input to the set.
If you think that something is causing the audio to be muted, you have to identify the path by which components are given a mute command, trace it back to the source and determine whether that is the case. What kind of consumer electronics have you been servicing?
