1 - 3 of 3 Posts
Plain ole user
JVC Americas Corp.
www.jvc.com
1700 Valley Road
Wayne, NJ 07470
973-317-5000
800-526-5308
Customer Service
800-252-5722
Parts
800-882-2345
800-446-0085 fax
Service Center Locator and Factory Service Status
800-537-5722
Factory Service Centers:
JVC Factory Service Center
16 Chapin Road, Suite 910
Pine Brook, NJ 07058
800-252-5722
JVC California Factory Service Center
5665 Corporate Avenue
Cypress, CA 90630
800-252-5722
JVC Hawaii Factory Service Center
2969 Mapunapuna Place, Suite 105
Honolulu, HI 96819
800-252-5722
JVC Illinois Factory Service Center
705 Enterprise Street
Aurora, IL 60504
800-252-5722
JVC Georgia Factory Service Center
1500 Lakes Parkway
Lawrenceville, GA 30043
800-252-5722
JVC parts can also be purchased from authorized distributors such as:
TriTronics
Vance Baldwin
Andrews
Fox
JVC TVs — Service Menu Access Codes
JVC
Plasmas / LCDs
  • Press the {MENU} button and go to the User Menu screen, make sure
    that the indicator (arrow) is pointed and highlights the "Picture Control".
  • The buttons on top of the remote are set to TV & VCR respectively.
  • Set sleep timer to "0" minutes and while it is displayed, simultaneously
    press the {VIDEO STATUS} & {DISPLAY} buttons.
  • The Service Menu will be displayed.
  • Use the number keys {1-9} to select a category.
  • Use the {CH+} {CH-} buttons to select options.
  • Use the {VOL+} {VOL-} buttons to change settings.
  • Use the {MUTING} button to save settings.
  • Press the {BACK} button to exit the Service Menu.
    service code posted by Frawls1
JVC
MISC TVs
  • Turn the TV on.
  • Using the remote control:
  • Press the {INFO} & {MUTE} buttons at the same time.
  • Use the number keys {1} - {9} to select a category.
  • Use the {VOL+} {VOL-} buttons to enter the category.
  • Use the {CH+} {CH-) buttons to select options.
  • To exit, press the {INFO} button.
    VESTEL
  • Turn the TV on.
  • The Service Menu will be displayed:
    • ADJUST
    • OPTION (Don't change anything)
  • Select "Adjust".
  • Use the {UP} {DOWN) buttons to select options.
  • Use the {LEFT} {RIGHT} buttons to change settings.
  • To exit, press the {MENU} button.
    VESTEL 11AK45B5
  • Turn the TV on.
  • Press {DISPLAY} & {PIC MODE} buttons at the same time.
  • Use the {UP} {DOWN} buttons to enter the category.
  • Use the {LEFT} {RIGHT} buttons to select options.
  • Use the {UP} {DOWN} buttons to change settings.
  • To exit, press the {DISPLAY} button twice.
  • Press the {MENU} button.
  • Select "Clock Set".
  • Set clock to 3:21 AM and press "Start Clock".
  • While a "Thank You" message is displayed on screen,
    press the {MUTE} and {MENU} buttons.
  • The Service Menu will come up.
  • Use {UP} {DOWN} to select options.
  • Use {LEFT} {RIGHT} to change settings.
  • To exit, turn the power off.
  • Press the {DISPLAY} and {PIC MODE} buttons
    at the same time on the remote control.
  • Use the {MENU UP} {MENU DOWN} buttons to select options.
  • Use the {MENU +} {MENU -} buttons to change settings.
  • Press the {DISPLAY} button to exit menus.
  • Press the {DISPLAY} button again to exit the Service Menu.
  • Then press the {4} {7} {2} {5} buttons.
  • Use the {UP} {DOWN} buttons to select items.
    VESTEL
JVC
Projectors
  • Press the {UP} {DOWN} {RIGTH} {LEFT} buttons.
  • Then press the {ENTER} button.
1 - 3 of 3 Posts
