1 - 3 of 3 Posts
How's it going gentlemen? Hope all of you get to spend time with your families for the holiday.
Debating whether to get the KEF LS50, or to get a better subwoofer. Considering the JL Audio E110 & E112, SVS PB13, Power Sound XV15 (just recently learned about the XV15. Appears to be the best subwoofer under 1k & performs with many above 1k) and the HSU Research VTF 15H. Also recently found out that HSU is going to be releasing the MK 2 soon which is very intriguing.
I would replace my Q700's for the LS50's. The subwoofer I currently have is a good, quality sub in the NXG BAS 500, just looking for more power with a lower cleaner bass.
Do any of you own the LS50?
What do you recommend? Appreciate any advice gentlemen
Hope you and yours have a great Thanksgiving
This is very dependable on your taste.
I would listen to both scenarios, in your room (your initial opinion is normally the best).
You are satisfying yourself, no one else.
1 - 3 of 3 Posts
