1 - 4 of 4 Posts
G
Hey all,
I just unearthed my old Kenwood SS-992 from my garage. We had it hooked up in my old house, but when we moved, procrastination set in. So today I found some free time and hooked it up, however, when I turn it on, it starts up and says "Dolby" and seems to be normal for a few seconds, then it switches over to flashin the word "PROTECT" and none of the buttons work.:doh:
Any ideas??
... when I turn it on, it starts up and says "Dolby" and seems to be normal for a few seconds, then it switches over to flashin the word "PROTECT" and none of the buttons work.:doh:..
I think there's something making a short circuit and that's why is going into protection mode ...:yes:
Did you connected speakers??? ... first, look to see if wires (+ and -) are touching.
Check the power cord (maybe is bad).
G
Yeah I think both of you are right. I just shut it off and unplugged it for a while and let it sit with the cover off.
A couple hours later I plugged it back in and it worked fine
:-D
Thanks all!!
1 - 4 of 4 Posts
