1 - 2 of 2 Posts
Hi,
i would like to know if this is a good setup because the Klipsch has got more dynamic range than Bose Frequencies. My setup is to connect the Klisch Quintet 5 speakers directly to
Onkyo tx-nr 708 to FRONT-R, FRONT-L, CENTER, SUR-R, SURR-L.
Then Bose accoustimass speakers to
FRONT-Wide-R, FRONT-Wide-L, SURRBack-R, SURRRBack-L.
This bose system has got an LFE input that can be connected to the LFE Output on the receiver. Also I will not connect the Bose Center Speaker. The bose settelite speakers are connected to the bass module and to the receiver as described above. So want to clear out if there will be issue with low frequencies or not. For my understanding, the receiver itself will know where to send the signals to the right channel.
No comment from me about whether that is a good set up, but the way you describe it, it should work properly. The Bose bass module will take care of the bass for it's satellite cubes and it will take care of the LFE signal.
1 - 2 of 2 Posts
