1 - 4 of 4 Posts
Whats the best place to put This center channel?? For best sound quality.
I tried google but cannot find much good info.
http://www.klipsch.com/kc-25-center-speaker
I have KF-26 Floorstanding Speakers as fronts, Well timbre matched with KC-25 woofer size/horn.
I am considering building a custom TV stand for Center placement & Onkyo Receiver but I cannot afford to build it right now unless I use scrap Maple Plywood.
Thanks:T
I will agree with Sonny.
On another note I am not a fan of putting a speaker in a box (cabinet). Depending on what your doing with the TV if its wall mounted you can the center just below it on a floating shelf, or put in on top of the short cabinet.
Ill take pic soon the horn is in line with my floorstanders right now sounds really good there I might build as specialized stand in for them.
1 - 4 of 4 Posts
