You have to get the specs for the graphics system in the laptop. Open your Display Settings (in Windows settings) and determine what the highest resolution setting listed for your video subsystem... if it gives you only options from 1080p and lower, you can't get the laptop to output a UHD source with UHD resolution. To get HDR and 2160p, the graphics subsystem in the laptop has to be new enough for HDR to have existed when the laptop was manufactured (so laptop has to be maybe 4 years old or less). If you do not see 2160p as a resolution you can select from the video display settings, you can't send 2160p to a TV over HDMI. BUT, put your TV on your network and if you have a smart TV, you can download a media player app (Kodi is the most stable I've used on TVs, VLC and Media Player have both been buggy. Then use the navigation available in the TV media player to locate the 2160 video on the device connected to your computer (you may have to "share" that device if it is not already shared, in order for this to work). In THAT way, you can get the content to the TV in 2160p. This way, the TV is downloading DATA from the device storing the TV programs instead of the laptop being the rendering device and sending the video over HDMI.
