21 - 40 of 49 Posts
I was meaning the LP being at 1/5 since the subs are tucked in the corners. How far are your mains off the front wall?
Sent from my iPhone using Tapatalk
Discussion Starter #22 (Edited)
3 ft from side and about 2 ft from ft.
Yes I'm using the built in test tone on my lexicon pre/pro.
I can try moving the listening position forward some. You will see when I post pics tonight. It is a very large L shaped couch. I'm not sure if I can get 3 more feet or not. Bit I will try.
Time is short at this moment but how about a shot of the back? 2/3 of my subs are behind the LP in corners. Just a quick idea...
Discussion Starter #26
Here is a better shot of the subs up front on either side
There is no rush. This will be a month or 2 long project to get it the way I want it. I appreciate everybody's help and input. As I said before, I want to do it right this time and not just throw it together to make it work.
Discussion Starter #28 (Edited)
No not facing the wall. I had them behind the couch on the side wall face toward the center of the room behind my head at the mlp. I will try that this weekend. My umik should be here fridayish and I can fire up rew. I know this is a lot of guess work at this point.
I do have a question about listening position and the 1/5th or 1/3rd the length of the room. If I understand this correctly. I'm going to try to move the couch back to both location and run some tests with few.
Thanks again everyone for the help and input. I will need a lot more in the coming months.
Well I'm off to Lowes to get materials for bass traps and rear wall treatment. I will post pics when they are up.
Discussion Starter #29
Well diy corner bass traps on finished and in. I notice a diff in sound in the room. Not sure how to describe it yet tho. Will put up measurements soon.
Hello,
Just one question.
What is bad with a null?
Basically the human ear works differently than the microphone that is used for measurements.
The microphone just records sound levels when such measurements are being made , independent of the time structure of the sound.
It does not distinguish between the first wavefront and reflection that arrive at the same time as the most recent wavefront but originated with a different wavefront much earlier.
The microphone just sums up the sound pressures and thus also detects when those sounds cancel reach others out (nulls)
The ear does does distinguish between the first wavefront and reflections because it analyzes the time structure of arriving sound patterns.
That's why our ears are also not really sensitive to comb filter effects.
A null is just a position, the direct sound, the first wavefront is not being disturbed by room resonances.
One can still hear the respective frequencies very well. Just try it out with sine waves with the respective frequencies.
I would rather be worried about the resonances that increase the sound level at certain frequencies.
Cheers
Babak
Cheers
Babak
Nope. Not true. I've tried this many times before I had REW. Manually implemented sine waves, and an spl meter can show in real time which frequencies are cancelled, or exaggerated by the room. Time doesn't alter this. The LP position, or wave propagation location does. That's why moving speakers/subs, or the LP alters the effect.
Well, an SPL meter is also a microphone and does not resemble the human hearing.they both only measure sound pressure.
It doesn't make sense to conclude an audible effect based on a measurement with devices and methods that work completely different than the human auditive system.
The question is if it's really a null (of a room mode) or some cancellation at that frequency (a low frequency comb filter effect).
If it is a real null, than great!
Put the speakers or subs right on the null. There they can't excite any room resonances at the respective frequencies.
Also put the listening position onto a null. The resonances with the respective frequencies will have the least sound pressure and hence the least audible effect there.
That's also in line with recommendations by Floyd Toole.
Of it is a comb filter effect at a low frequency - just forget them.
The human ear is not sensitive to comb filter effects (proven in studies).
A comb filter effect is just something that looks ugly on a measurement graph because - yes microphones vs ears.
What else can that null be that needs treatment?
I guess it depends on what the null is from.(I think that's also what you're saying). Fwiw, when manually running and measuring tones, my ears heard the differences in level. If a null is created by the room, the only help is relocating equipment or LP. If a null is a phase issue then that can be addressed. I also still say nulls need to be addressed whether there created by the room, or equipment. Do I understand you to mean that nulls from phase, or comb filtering are just measurement anomalies that should be left alone, as the ears are not effected the same way a mic is?
That's right
Of course.
Can you tell whether that is because the respective frequencies are reduced or those frequencies are at normal level an others around them are increased in level due to resonances?
Here one should also keep in mind that due to the loudness cuves of the human ear we perceive low frequency sound with a lower loudness anyway.
Of course fluctuations in the frequency response need to be addressed.
I personally would rather focus on the peaks and resonances rather than the nulls and dips.
Yes and no.
I wouldn't say that they are abnormalities because they can be clearly measured - repeatedly and consistently.
And yes, the ears are not effected the same way as a microphone is that one users for measurements.
Cheers from Vienna
It looks like you are about a foot off the from wall. Spin them 180 degrees & measure again. That will effectively change the null ~2 feet. If still bad can you then move them out 1 more foot from the front wall.
Discussion Starter #39
Right now they are 6' off the front wall. Both subs are pointing inward toward the center of the room. I can spin them 90' and have them face toward to back of the room.
I will post rt30 and rt60 later today.
BC, wish I had something to offer on your waterfall. Looks like extra ringing between 35 and 55hz. Traps? That's all's i got...
21 - 40 of 49 Posts
