41 - 49 of 49 Posts
Discussion Starter #41
I built 2 large corner traps in the rear corners. Can't do the front corners. Where else should I built some? Ceiling to wall corners around the tops of the side or front walls?
I would try Bryan from GIK. He chimes in regularly, and I've seen him support the diy enthusiast. He's also quite brilliant.
Sent from my iPhone using Tapatalk
Discussion Starter #43
I taken to Bryan. He said more low end bass traps. I guess I have a weekend project. Will post new waterfall soon
I did see the thread you started. I was hoping he would drop in. Looks like you're going the right way.
Discussion Starter #45
It is more difficult than I thought it would be. I figured you put in some corner trap and panel at reflection point and then you are good to go. I was wrong...
41 - 49 of 49 Posts
