You don't need most of those parameters. Post the parameters that you do have.
Yeah that alignment usually works well with the TC-2000I came up 4 ft^3 with 1000 grams on each p.r. and it give's out 19.94hz. Is that good?
I am having a problem with WinISD Pro 0.50a7 that is very similar to the problem BuddahX reported. When I start the program, it appears to work, but when I try to access the help files, the program is unable to find them. Then, when I try to close the program, the close button does not work and I get "Access Violation at address 00000028. read of address 00000028". I am forced to use Task Manager to close the program.I still get "Access Violation at address 00000028. read of address 00000028"
