So this is a 1/2" total thickness product? If so, I really recommend to increase the mass by adding a thick sheet of drywall behind that finished material.
Are you planning to incorporate acoustic treatments on the walls? Often the walls are completely covered with treatments. In that case there's not much use in applying a finished panel like you're showing.
Just trying to fully understand what you're goals are.
Thanks,
Thanks,
