1 - 20 of 58 Posts
Light Illussion's LightSpace DPS (Free Display Check Version of LightSpace CMS) now supports up to 21-Point Cube (9.261 Color Points) Free Display Verification for daily performance test where accurancy is very critical.
Verification
LightSpace DPS has one main function - to be used for Display Profiling and Verification, allowing the user to determine if a given display requires re-calibration or not.
With LightSpace DPS it is possible to use any of LightSpace's profiling capabilities, but without the ability to 'save' any profiles. All checking needs to be performed on the profile before closing the software.
It is also possible to generate a LUT from the profile, which aids checking the profile information as the 3D cube view and 1D graph LUT will show the necessary corrections required for the display profiled. The LUT can also be 'virtually applied' to the display for re-profiling, howing the effect of the LUT corrections.
High Accuracy
Unlike inferior display checking systems, LightSpace CMS is not limited to a small range of colour patches, providing 'Quick Profiling' for daily checking, as well as full cube based profiling, including 21^3 with 9261 individual colour patches (and beyond) for unlimited accuracy when verifying the accuracy of any given display.
Quick daily verification takes seconds, and ensures no display drift, while full cube based profiling ensure any given display is actually accurate to the required colour space target.
Simple Confirmation
Display accuracy is simplicity itself to check, with the closer the cube image is to being a cube, the better the accuracy.
And being able to rotate the cube in 3D space makes it simple to spot any colours that are inaccurate anywhere in the volumetric colour space.
All this in addition to standard CIE, DeltaE, gamma graphs, including LightSpace's unique RGB Separation graph.
RGB Separation
RGB Separation' is a very quick and simple guide to likely display accuracy.
If this graph shows errors the display has to be considered inaccurate.
Free Download Link
This license will activate the standard LightSpace Demo Download, turning it into the 'free' profiling version. The LightSpace CMS demo program needs to be downloaded separately.
Discussion Starter #2
LightSpace CMS 6.6.3.1986 (13 October 2014)
A new version of LightSpace has just released.
This version includes:
-- Auto Close option added after Display Characterization
-- Lumagen Radiance 21xx 17^3 LUT support added
-- Additional EIZO integration added
-- BON display integration added
-- Additional Arri Look tools added
-- Support for NEC display calibration integration
-- Additional LUT formats added
Download LightSpace CMS Demo or Upgrade for Licensed Users
Request Free Version License for LightSpace DPS (Display Profiling System)
LightSpace CMS 6.6.4.2004 (10 November 2014)
-- Upload thermometer added
-- Auto Close option added after Display Characterisation
-- Lumagen 17^3 LUT support added
Discussion Starter #4
LightSpace CMS 6.6.4.2010 (19 November 2014)
-- Save Probe settings between program close/open
-- Colorimetry Research CR-250 integration added
Discussion Starter #5
LightSpace CMS 6.6.5.2021 (12 January 2015 - Closed Beta)
A new version of LightSpace has released at closed beta that adds support for the MadVR's Test Pattern Generator that is now controlled by LightSpace. The users can select custom pattern sizes with APL also and feature direct LUT Upload into madVR.
There more instructions available here: http://www.lightillusion.com/madvr_manual.html
Public release will be out very shortly.
Discussion Starter #6
LightSpace CMS 6.6.7.2061 (24 March 2015)
Light Illussion has just released the Next Generation of Color Mathematics for it's advanced Color Engine, which is at the heart of the unparalleled calibration accuracy of LightSpace CMS.
The original Color Engine had previously proven to be the most accurate, as well as the fastest available for display calibration, LUT generation, LUT conversion and LUT manipulation. However, nothing is ever perfect, and Light Illusion knew they could do better. After over 6 man-months of work the algorithms and mathematics that are at the core of the LightSpace Color Engine have been totally re-written and enhanced, with visible and measurable improvements in final calibration results.
Note: for users that have performed a recent display profiling, they don't need to re-measure again their displays. It's required only to install the new LightSpace version, load their measurement file and generate the ColorSpace conversion to get the new 3D LUT correction file and then upload it to their 3D LUT hardware device or to their 3D LUT capable monitors. This saves a lot of time.
Full Release Notes @ available here.
-- New Colour Engine mathematics and algorithms
-- New LUT Format for Canon 4K Professional Displays
-- Changed operation of VideoScale functions
-- Changed defaults for Convert Colour Spaces
-- Added Differential Gamma graph
-- Added support for DVDO AVLab TPG patch generation
-- Corrected Active LUT effect on initial patch in Measure mode
-- Fixed error with Probe Settings not being remembered correctly
-- Small changes for CR-250 integration
-- Added error message if CDL/CCC file invalid
-- Corrected minor Convert Colour Space white loss
-- Changed UHDTV label to UHD Rec2020
-- Added ST2084 Gamma profiles for Rec709, Rec2020, and P3
-- Fixed error with Hubble probe connection
-- Fixed duplicate LUT being applied to Ref Image when exporting Arri Looks
Discussion Starter #7
LightSpace CMS 7.0.0 is coming….
For LightSpace users, there some real interesting new features like these ones you can see below:
Quick Profiling
Additionally to the Quick Profiling of Primary/Secondary Colors measurements that were available since now, Gamut Saturations @ 75% or 100% Stimulus Level and Memory Colors (Color Checker Classic) options added, to quick overview the performance of any display.
Here is an example of the CIE chart after the Memory Colors measurement:
Gamut Triangle Level
The new Gamut Triangle Level function enables the visualization of a display's gamut at all matched RGB primary points throughout the full stimulus range. By cycling through list of available matched RGB primary points it is possible to see the shape and size of the Gamut, and see at what levels it is smaller or larger that the desired target.
When you will run a Quick Profiling of Primary Colors which measures 20-Point of Luminance per color channel @ 100% Saturation, you will be able later to check the 100% Saturation of any Luminance level to overview the gamut coverage triangle over these 20-Point Luminance levels to check if the gamut coverage remains the same or if is reduced; to find which pre-calibration settings give the largest coverage etc.
This is extremely helpful when it comes to understanding the underlying capabilities of a given display.
Stimulus Levels
The Stimulus Levels function is another of the 'filters' for the CIE graphs, and defines how the measured points are shown. As with all the points filters they are additive options, and will combine with any other filters selected. The Stimulus Levels filter will show any and all points that include the selected value within any R, G, or B stimulus data. This enables easier selection of a given point to enable it to be isolated via a double click to see the points associated measured color data and Delta-E values.
Delta-E
You can display at the CIE Chart only the colorpoints with the selected dE range, to check what areas of the display have more errors.
The Delta-E filter is also another of the 'filters' for the CIE graphs, and defines how the measured points are shown. As with all the points filters they are additive options, and will combine with any other filters selected. Therefore to see just the points within the available Delta-E ranges first disable all other filter tick boxes. The benefit of this filter function is that it enables a quick assessment of the spread of Delta-E values within the measured profile, allowing a very quick understanding of the overall accuracy of the display.
Reports
The new Reporting feature enables a .pdf export of the various graphs, as well as details on various aspects of the selected profile, including Luma range, contrast, Delta-E ranges, etc., as well as user editable sections for client name, display, probe data, and more.
Discussion Starter #8
LightSpace CMS 7.0.0.2155 (15 June 2015)
Light Illusion releases Version 7 LightSpace CMS – a major features update.
New features include:
-- Added new Maths functions for LUT Manipulations
-- Added ‘Sweeps’ to Quick Profiling options
-- Added memory Colours to Quick Profiling options
-- Added EBU TEC3320 colour space pre-set
-- Error message if Colour Space name invalid
-- Additional CIE graph display filters and features
-- Export PDF report capability
-- New LUT formats
-- BON 1D & 3D LUT Upload
-- ACES v1 fixes (for ACES not LightSpace)
-- Correction for madVR integration
-- Added gamut control for displays with limited gamut
-- New Manual Measure feedback Zoom graph
-- New Patch Colour section for Manual Measure
-- Added new AIO (all-in-one) mode for i1d3 RevB
Many if these new feature are all-new, and will be built upon in the coming weeks and months, with further updates being released for all LightSpace CMS users.
As is the case with all LightSpace updates, the new features are free to all users with valid option licenses that include the areas within which the new feature are contained.
The on-line user guides have been updated to include the new features, and it is recommended that all users refer to these, as some changes alter the previous operation of some LightSpace CMS features and functions.
Discussion Starter #9
LightSpace CMS 7.0.0.2164 (30 June 2015) just released.
New features
-- Added Konvision Broadcast Monitors Integration and Direct 3D-LUT Uploading
-- Added Prisma 3D-LUT Box Integration and Direct 3D-LUT Uploading
-- Changes of Sliders Link function
Discussion Starter #10
LightSpace CMS 7.0.1.2171 (12 July 2015) just released.
Changes
-- Changed Colour Space default to Peak Chroma
-- Fixed Parametric Gamma Save bug
-- Changed DVDO Baud Rate
-- Added YC422/YC444 output option for DVDO AVLab Test Pattern Generator
-- Fixed Active LUT for Manual Measure & Quick Profile
-- Klein K80 added to Discoverable Probes
-- Fixed Java App crash with Patch Sliders
-- Corrected PR-670 Luma level reporting
Discussion Starter #11
LightSpace CMS 7.0.1.2172 (13 July 2015) has just released.
This is minor bug fix release. Not affecting LightSpace's Engine. Generally, for LightSpace users that have performed a recent display profiling and see that a new LightSpace has been released where it features some improvement in colorspace correction (for example), the users don't need to re-measure again their displays. It require only to install the new LightSpace version, load the latest measurement file and generate the ColorSpace conversion to get the new 3D LUT correction file and then upload it to their 3D LUT hardware device or to their 3D LUT capable monitors. This saves a lot of time.
Discussion Starter #12
LightSpace CMS 7.0.3.2214 (28 August 2015) has just released.
Changes
-- Added Max Exposure setting for CR-100 probe
-- Added Integration Time setting for CR-100 probe
-- Corrected Sliders operation
-- Corrected Prisma Upload functions
-- Allow BT1886 to be saved with changed gamut values
-- Added Kroma monitor integration
-- New LUT formats added
Download Links
Discussion Starter #13
LightSpace CMS 7.0.4.2251 (28 September 2015) has just released.
Changes
-- Anisometric Profiling patch sequence option
-- Canon display integration
-- Windows 10 COMs port issue resolved
-- Added TVLogic Binary LUT format
For OLED's/HDR displays it's been added an Anisometric Profiling patch sequence order option to LightSpace.
Anisometric sequences are better suited to displays that have any form of ABL, such as Plasmas and many OLEDs, and which also includes HDR displays where Sequential patch ordering can cause display overheating (overheating can actually be an issue on any display that has high peak luminance outputs, as it can cause the display to drift.
Download Links
Discussion Starter #14
LightSpace CMS 7.1.0 Beta is available for testing / close for final release.
Changes
-- Altered Scroll Bar operation.
-- Changed operation of the Luminance Thermometer.
-- Added Min/Max Luminance to ‘Options’ menu for Manual Measurements.
-- Added new RGB and Delta-E Bars Widget to Calibration Interface.
-- Changed AEQ/Kroma display Upload function.
-- Changed Gamma and DifGamma graphs to show RGB values.
-- Added support for PR-653 Cinebrate probe.
For those who want to take a test drive you can contact LightIllussion or send me a PM to provide the download link.
For LightSpace users, there been added 2 new helpful User Guides:
For Manual Display Calibration: http://www.lightillusion.com/manual_calibration_idiots_guide.html
For 3D LUT Calibration: http://www.lightillusion.com/lut_calibration_idiots_guide.html
Discussion Starter #15
LightSpace CMS 7.1.0.2292 (02 November 2015) has just released.
Changes
-- Added % values option to scroll bar
-- Added support for Eizo CG248 and CG318 4K monitors
-- Set EBU default Gamma to 2.4
-- Correction for DigfGamma graph plot
-- Change to correct Resolve 1D Shaper LUT extension
-- Fixed occasional crash when matching Profiles to Profiles
Download Link
Discussion Starter #16
LightSpace CMS 7.1.1.2303 (08 November 2015) has just released.
Changes
-- Added Drift Compensation for display & probe time based drift
-- Fixed ‘Ftl’ Luma graph & value display issues introduced in 7.1.0
-- Corrected PDF Report Luma values, also introduced in 7.1.0
-- Added larger Cube display options to 3D Cube viewer
-- Corrected ACES Gamut plot triangle
Download Link
Discussion Starter #17
LightSpace CMS 7.1.1.2304 (17 November 2015) has just released.
Changes
-- Fixed 'Ftl' Luma graph value display issues introduced in 7.1.0 and first 7.1.1 release.
-- Corrected PDF Report Luma values, also introduced in 7.1.0 and first 7.1.1 release.
-- Added Prepend/Append capability to 'Maths' function.
Download Link
Discussion Starter #18
LightSpace CMS 7.1.1.2305 (19 November 2015) has just released.
Changes
-- Corrected RGB Bars Widget display
Download Link
Discussion Starter #19
LightSpace CMS 7.1.1.2307 (19 November 2015) has just released.
Changes
-- Fixed RGB Bars Widget display
Download Link
Discussion Starter #20
LightSpace CMS 7.1.2.2341 (14 January 2016) has just released.
Changes
-- Added BBC HLG Gamma profiles for Rec709, Rec2020, and P3
-- Added graphing for ST2084 and BBC HLG standards
-- Apply Probe Offset data when setting display Min/Max Y in Options
-- Corrected Manual Measure values when using BT1886 as Target colour space
-- Corrected various FtL value display errors
-- Added image extension to 'Save As' from LUT preview function
-- Increased Cube Size for ACES CTL export
Download Link
1 - 20 of 58 Posts
