1 - 20 of 34 Posts
I've always been a DIY sub woofer guy. I'm wanting to build a couple towers and wanted something kinda easy. So I was thinking about building two Line array towers using 16 Dayton ND90-8 3-1/2" Aluminum Cone Full-Range Driver 8 Ohm in each tower. Total height would be around 56". Another thing I was wondering is wiring. If I wire it in the diagram provided would I get a 8 ohm load. I think I will if I did my math right. But this is the biggest thing... The crossover. I have never built a crossover designed one or know what parts look like or what they do. Thank you for your help and information. If I get the help needed for the crossover then I will be building these in February and have a good Idea on the cabinets.
edited comment: was thinking about going a different way in spite of the price I think I would rather stick with the Dayton's.
for the crossover? I know the impedance will be 8 ohms. Figured it out lol. I couldn't find any calculators but maybe I just wasn't searching right.
The issue with full range drivers is that they have ragged response.
Take a look at the response of the dayton you're looking at using... a 10db window! +/- 5 db is just not a flat frequency response. Two of the most important aspects of any speaker is to have a flat on-axis frequency response (+/-2db from 200hz-8khz) and a close off-axis response. If your driver needs heavy EQ then your results are not going to sound smooth or realistic. It'll sound like a cheap stock car audio in terms of "true-to-life".
My advice is to keep it simple and go with another person's design.
http://www.parts-express.com/projectshowcase/indexn.cfm?project=Colossi
http://www.parts-express.com/projectshowcase/indexn.cfm?project=Kuze3201
http://www.parts-express.com/cbt36/...t=DON+KEELE+CATALOG&utm_campaign=Catalog_2011
Honestly though I don't know if line arrays are a good place to start. I think there's lots of options out there for you that might not cost as much on raw drivers.
My suggestion would be to do a Zaph ZA5.5tt kit from madisound.
http://www.zaphaudio.com/ZA5/ZA5.5tt-FR.gif
As you can see he keeps it within a ~4db window in the range I alluded to earlier. He's a great crossover designer and will really give you a small taste of what DIY can net you.
Once you've gotten your hands dirty a bit, then try your hand at a simply two-way three driver MTM speaker.
I really would want those CBT36's but all those are out of my price range. What would you recommend for a Kit DIY towers under 1000? I really don't know enough to do something on my own. They will be used for movies and music. Thank you for your input and help. that would suck to spend all that money to find out I don't like the way they sound.
TriTrix MTM TL Speaker Package: Cabinet Kit and Components. what do you think about these. There pretty cheap so I don't know if they sound good or not.
The TriTrix package gets alot of good reviews so i don't think they would dissapoint.
It's a good entry level build if you just want some experience with wood working without breaking the bank. Curt Campbell is a very good crossover designer. If that's your budget, then it's a good choice, but if you've got more flexibility, you can make a huge improvement even by just doubling the budget. Here's a really nice MTM tower speaker designed by Dennis Murphy (who also designs the majority of Salk Sound speakers):
http://forums.audioholics.com/forums/showthread.php?t=68531
The Zaph ZA5.5tt looks sweet as well, I posted it earlier. Definitely keep it as an option as it's not only a great crossover but a very nice driver.
If you don't mind going a bit old-school with a good ol monkey coffin, there's another very nice Zaph speaker:
https://www.madisound.com/store/product_info.php?products_id=8691
The parts for the woofers don't appear to be in stock right now but another excellent choice for bang-for-buck and sound quality is this guy:
http://www.zaphaudio.com/ZDT3.5.html
and to top it off, Krutke has yet another sweet design, the TMM waveguide speaker:
http://www.zaphaudio.com/Waveguidetmm.html
If you want to broaden your horizons, you may want to consider a dipole speaker such as this one by Paul Carmody:
http://sites.google.com/site/undefinition/diy-sunflowers
Here's another one by Carmody:
http://sites.google.com/site/undefinition/tarkus
Now back to curt campbell. Yes, he designed the Tri Trix, but he also made these:
http://speakerdesignworks.com/Statements.html
and their little brother
http://speakerdesignworks.com/MiniStatements.html
The statements series all have centers designs too so it may be a great choice for you.
As you can see there's lots of options out there. Basically if you've got a crossover schematic, it's just a matter of soldering it - it's not hard - just go along slowly and carefully and make sure to place inductors properly. The complex part of any speaker design part is actually making the crossover as it requires the right equipment and understanding.
Discussion Starter · #14 ·
Oh and thank you so much for your help. I'm def a newb when it comes to the main speakers lol.
http://www.parts-express.com/projectshowcase/indexn.cfm?project=MillenniumIII what do you think of this setup. It seems pretty good and I like the looks. and its right at my price range. I'm also liking the dipole one you posted up.
dont know much about it... just read up on peoples impressions of it and anything else ;-) and see where your gut takes you. just make sure the designer is providing good build info and detailed measurements to verify a good design. if the designer doesnt communicate well or the crossover topology confuses you then u may run into problems.
a good way of verifying a design is comparing most of the measurements to the Revel Salon2 measurements on stereophile. lol.
now regarding dipoles i want to point out that they have interesting characteristics that a passive crossover may not be able to beat as the back waves cancel the front wavea. if u want to do a dipole perhaps consider an active one like the NaO and Orion
Discussion Starter · #18 ·
I decided to try my own thing. Using woofers, tweeters, and Dayton 2 way X-overs from parts express. Might not be as good as the DIY kits but it will be more in my price range and I can build 7.2 cheaper. I know it prob wont sound as good but I think it will do for what I'm doing. I don't have a very picky ear so I think it will be fine. once I get everything and designed the cabinets I'll post up a build thread. thank you everybody for your help and information.
That's the worst possible route you could possibly take. It might be cheap but it won't be decent at all. You're better off with your original line array idea.
I strongly recommend against ever using any readymade crossover.
yep.. it won't sound any good.
Making noise?
You'd better hope so, because chances are it won't even sound half decent. A ready made crossover is destined for failure. Like, worse than the cheapest HTIB at wal mart.
1 - 20 of 34 Posts
