Status
Not open for further replies.
1 - 2 of 2 Posts
Super Moderator
Discussion Starter #2
My Stage and FOH-Friendly Bass Rig
Instruments
  • Allen Breaux Boogie Man custom hand-made 4-string.
  • MV Pedulla Thunderbass ET5 5-string.
  • MV Pedulla Thunderbuzz ET5 fretless 5-string.
  • Tobias Classic 5-string.
Main Equipment Rack
  • Furman PL-Tuner power director/tuner (modified for rear signal input).
  • Ashly BP-41 pre amp.
  • dbx 160X compressor.
  • Ashly SRA-2150 stereo amplifier (80 watts per channel @ 8 ohms, 150 watts @ 4 ohms (for at-home practicing or other on-stage uses as needed).
The main rack is used for gigs where no stage rig is needed due to full PA support with subwoofers, supplying a balanced line out to the house system. If there is no in-ear monitor system I’ll use the EV speaker listed below to hear myself, powered by the Ashly amplifier. A patch panel on the back of the rack also allows me to also utilize the Ashly amp for specialized needs, such as a dedicated monitor to better hear the primary vocalist, guitar or keyboard player.
Secondary Equipment Rack
  • Yamaha YDP2006 stereo digital 6-band parametric equalizer (as crossover and EQ).
  • Crest Audio Pro7200 stereo amplifier (590 watts @ 8 ohms,1000 watts per channel @ 4 ohms).
For gigs where there is minimal PA support and my stage rig needs to carry the house, I add a secondary rack for a full-range bi-amped rig. Used with the Genzler and EAW speakers listed below.
Speakers
  • Electro Voice ZX 1 – 8” two-way speaker (as bass monitor if needed).
  • Genzler BA12-3 – 12” two-way cabinet.
  • Eastern Acoustics Works SB-150 15" subwoofer.
Accessories
  • Custom-made guitar cables with Canare L-2T2S cable and Switchcraft 226 90° plugs.
Instruments Pictures
MV Pedulla Thunderbuzz ET-5 fretless
(2006) Bubinga top plate
MV Pedulla Thunderbass ET-5
(2005) Cocobolo top plate
Tobias Classic
(1999) AAAAA quilted maple top with wenge tone plate and walnut back
Allen Breaux Boogie Man (custom hand-made)
(1994) Flame maple wings (top and bottom) with wenge tone plate; bubinga center with purpleheart stringers; rock maple bolt-on neck with wenge stringers
Equipment Pictures
Full Stage Rig
Rear View
Main Rack Rear Panel
Previous Rack Compliment, with Separate EQs for House and Stage
1 - 2 of 2 Posts
Status
