1 - 12 of 12 Posts
Where would be the best location (starting point) for installing ceiling traps to help with first reflections? As a general rule where to start? about even with the side wall panels? Half way between me and the speakers? More to front/rear of the area between me and the speakers???
Draw a diagonal line from each seat to each speaker. Go back 1/2 the distance of that line and that's the reflection. This assumes speaker height is approximately head height.
Hi Bryan,
Ok that seems easy enough, now once I get back half way down that line should I be on the line or just use the line as a measuring tool? In other words where on the ceiling do I want the 244 traps? If put on the line at the half way point they will be off to either side quite a bit, or just move them towards the center of the room staying at the half way mark of the line?
By the time you mark all 3 front speakers to each seat, you'll not have much choice by the time you try to cover all the points.
Ok what happens if my ears are about 6-7inches lower than the tweeters?
Only one seat so I am thinking of drawing a line from the top left corner through the bottom right corner of the trap, then putting that line in line with the line from the speakers to the listening position.
If the ears are slightly lower, the point will be slightly closer to the seats. With 6", won't likely move more than an inch or 2
Couldn't he get a friend to hold up a small mirror on the ceiling & move it aroung untill he sees the target speaker from his seating position? Seems like that would be easier than all the measuring.
Yes I could have but, I know where the first reflection point is for the most part. I was just trying to go about getting the max out of the traps by means of measurement.
1 - 12 of 12 Posts
