1 - 9 of 9 Posts
I am considering one of the two Logitech Harmony remotes (Harmony One or the 1000) and was wondering what some of you recommend? Based on my research (limited), the Harmony One is a fine remote that performs very well - thoughts?
Well I bit the bullet and purchased a Logitech Harmony One remote yesterday. It has a great feel and weight to it and the touchscreen is nice and responsive. I programmed it to pretty much control all the components in my HT system (including the Marantz AV unit) and it works perfectly!
I was faced with the same decision and also went with the Harmony One. I currently own a 670. There were a few reasons for this:
Price; the 1000 looks wonderful, but it ain't cheap.
WAF; the 1000 looks cool, but it would be more daunting to my wife I believe, whereas the H1 is "familiar/traditional".
"Sturdiness"; this is not based on any real research, but the 1000 looks easier to drop and easier to break, whereas the One is a pretty traditional remote (that I can likely slip into my cup holder when I am not using it).
So I ordered it. Haven't got it yet, but should be picking it up today.
Bah! I just got my Harmony Remote and the base will not charge the remote. I plug the cord into the base, plug it into the wall and there's supposed to be a glowy white lite on the base to indicate it has power. Mine has no light :(
I've tried multiple outlets so that's not the issue. I have tried reseating the power connector and cannot make the LED come on.
Not happy :(
Hey,
Thanks for the reply/suggestion. I tried that and it made no difference. I am pretty certain the issue is with the base. The remote itself turns on (from the partial charge in the battery), but when I put it on the base - nothing.
Can someone who owns the One confirm, does the light on the base glow ALL the time, or only when the remote is docked?
Well, I RMAed the One and got a cross-shipped new replacement. It all works good now. The light does indeed glow whether or not the remote is docked (but you can switch it off with a switch under the base).
The remote itself is very nice, feel better than my old 670. I haven't had a huge chance to play with it though because my HT is not yet set up...
1 - 9 of 9 Posts
