Can you upload the driver files for the TC and the JL?
that's exactly right... two subs. the designs i'm playing with are a single downfiring 10" driver in each sub, or dual opposed 8" drivers in each sub.You want to build 2 subs and each sub has two opposing 8" drivers?
Thanks for doing that, Mike... i found the same thing regarding output. the JL has about 5 hz more extension and 6 db more output.Assuming your files are correct there's no comparison in output between the two. The modeling shows the TC sub in 5 liters for a Q of.7, kinda small for a pair of subs in one cabinet. Both models are with 150 watts and the 17.7 HPF and 1 db of boost in the 25 - 30 hz range that the Bash 300 comes with from the factory.
i got my parameters directly from Thilo at TC sounds. when i mentioned that there were slight differences in what he sent me and what was posted elsewhere, he told me that the data he sent was more reliable and the specs needed to be updated.Your Epic 8 file parameters are different from what is currently being sold.
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=293-657&FTR=epic 8
Here are the specs that TC Sounds sent me...Your Epic 8 file parameters are different from what is currently being sold.
