1 - 5 of 5 Posts
G
Hi all,
can anyone give me some help on my 50 inch samsung dlp hdtv. model#HLs5065w. the audio POPs like the 4th of july then i lose all sound. can someone give me direction to fix this problem..thanks in advance.
...can anyone give me some help on my 50 inch samsung dlp hdtv. model#HLs5065w. the audio POPs like the 4th of july then i lose all sound. can someone give me direction to fix this problem..thanks in advance.
i think you'll get more suggestions if you post in this area Manufacturers Service Suport :yes:
I have a popping noise on my Samsung HLS6767 ... but what I find out is that is caused by the heat inside the TV :yes: ... but I never loose sound, the noise is not constant too :yes:
Plain ole user
If you confirm that the problem is in the set, all of the audio is on the main board, IIRC. Either replace that if you can confirm I am correct, or it will need troubleshooting to determine the defective components. These boards are not usually repaired at the component level, however.
G
shack thanks for the quick responce....i also need to add .....when the tv pops and the sound gets distorted and then i lose the audio.... I turn the tv off /unplug it and you can hear a click like it has reset itself.....turn the tv on and all is fine until the next time. wich could be minutes or days.. thanks again
1 - 5 of 5 Posts
