1 - 3 of 3 Posts
Bought new Samsung plasma TV PN60E530A3F. It has 2 HDMI and one component port. Having trouble3 connecting everything. Have Prism Motorola DVR VIOP 232, Samsung Home theater HT-C550 and panasonic blue ray player DMP BD75. Don't seem to be able to get anything but the TV to work. Had an older Samsung HDTV with no HDMI and everything was working. Tried using and hdmi splitter. Disaster.
Would appreciate some directions and help.
THANK YOU.
Joe
Recommend you review the TV setup instructions. Usually have to designate what inputs do what. They aren't just plug and play like the old tv's. Also would need more info:
What doesn't work?
How did you hook the differant products together (hdmi, digital optical etc.) Whats hooked to what?
Additionally, some components won't automatically output what you physically have connected. You may need to press some button on your DVR or HT remotes to select HDMI out even if that is the only cable you have connected in back. Lame, I know, but I've had a few components like that.
1 - 3 of 3 Posts
