1 - 2 of 2 Posts
Hello!
I have no technical issues with my current speakers (Fronts: Pioneer SP-BS41-LR | Center: Pioneer SP-C21 | Rear: Pioneer SP-BS21-LR | Wire Gauge: 14 AWG). The Pioneers AJ were my first (level entry) HT speakers on the limited budget I had back then.
Now I am simply looking for a neutral to slightly "bright" sound (better) audio experience from speakers that is compatible with a Denon X3300W and 14 AWG wires. I use my HT for movies and gaming in a small room (800 ft³+ 54 ft³ corner door space).
I am interested in speakers that are sealed or front port, bookshelf/satellite, not floorstanding.
I am keeping my subwoofer SVS PC12-NSD.
So far I narrowed down my choices of speaker setups I am looking at.
For now, which of these configurations would be the top for HT/gaming on my Denon X3300W?
Ascend:
HTM-200 SE x 5
$773
RSL:
CG23 x 3
CG3 x 2
$870
NHT:
C-LCR x 1
C-1 x 4
$1200
KEF:
Q650C x 1
Q100 x 4
$1250
HTS Moderator , Reviewer
If you're after a bit of high end sparkle the Ascend and RSL are probably out as they use soft dome tweeters. Typically speakers using those will have a smoother top end, with a bit less sizzle. The NHT's have an aluminum dome, while the KEF uses their Uni-Q driver, so of the 4 listed those are the most likely to give you a little intensity up top.
1 - 2 of 2 Posts
