1 - 5 of 5 Posts
Y
Guest
Greets,
I was comfortable with the prior rev. of REW but this latest version is throwing me for a loop.
When I take a measurement, I want my prior-measurement EQ settings left intact so that I can build on them. However it seems that with each measurement my prior EQ settings are lost [so I cannot continue to develop my correction filters].
What I am missing please? :surrender:
Thanks in advance!
Friend of the Shack
Hi YimminyNoodle,
Yep, that's the way it works. You can save them to a file and then load them into your most current measurement. Or you can go back to your previous measurement, ignore the graphs if you wish, and tweak from there.
There have been several requests for that change to be made, and there are others that feel it's a triviality to save/load. But that's the way it works.
Y
Guest
Thanks for the knowledge Otto. This is a great service.
OK say I've just taken another measurement and I want to continue tweaking from my last filter settings.
I see how to save settings but it is not intuitive to me how to load a saved setting.
How do you load a saved filter setting once a new measurement has been made?
Is it just so intuitive that I don't see it? :praying:
Thanks again!
Y
Guest
Discussion Starter #5
Awesome.
I'll give it another go.
Thanks brucek that's an intuitive graphic! :T
1 - 5 of 5 Posts
