Losing my mind tryin to build my dream HT...please Sub help!!
2277 Views 9 Replies 8 Participants Last post by  Thunderheader
I am in the process of putting together my dream HT, and I am lucky enough to have a real nice budget to work with. I have decided on everything except the subs. I love bass.... deep, powerful, accurate, and responsive. My room is 220 cubic feet sealed....but may one day have a bigger room. So I am not worried about a little overkill, that is my middle name. I have a budget of about $10,000 ( keep in mind that things are more expensive here in Sweden...so it won't go as far as it would in the US) for subs (plural!) and this is where I am stuck.
Note....I have decided on the Klipsch THX Ultra 2 7.0 speaker setup, my room will be acoustically treated, and I only care about Blu ray movies, no music. Plus my space is somewhat limited to a sub no bigger than the SVS Ultra 13.
I have basically narrowed it down to the following options:
1) Quad SVS Ultra 13's
2) Quad Klipsch THX Ultra subs
3) Dual DD-18's
4) Dual Def Tech SuperCube Trinity
5) Dual Jl f113's
I am open to all impressions anyone has with these subs and other recomendations. I am not too interested in best bang for the buck.....just best bang!
I want a setup that will give me it all. I am also not sure what multiple subs will provide, except that if setup properly that it will be "better". Thank you very much in advance.
1 - 10 of 10 Posts
Welcome to the Shack Aaron... :T
Did you mean 2200 cubic feet instead of 220? :bigsmile: Four of any of those in 220 cubic feet sealed will cause you to go deaf quickly. :yikes:
I cannot speak for the other subs, but I had a pair of PC13-Ultra's in my sealed 1800 cubic feet HT room and they banged beyond my imagination. Granted, I did add a DIY sub later, but not because the Ultra's did not suffice, it was because I wanted to tackle the DIY build. The Ultra's were really all I needed. I can't say enough good about them.
Well, I just re-measured my room (yes it is 2200 cubic feet...that was a mistake) and I am going with dual Jl F212's. I will also have the Klipsch RF-83 speakers, and the size of the Ultra is too big for where I want to put them. Plus 2 speakers will be easier to dial in with the as-eq1. Not only will 2 subs be more asthetically pleasing, but the F212's should demolish my room!:hsd: I will own this setup 4Life, so I might as well get the subs I truly lust after:devil:
I know I didn't list the F212's originally, but after talking to Carl Kennedy of JL, I feel these will give me all the performance I will ever crave, and stomp out that nasty case of the upgraditis before it hits!
for 1 JL Audio Fathom f212 subwoofer: "MSRP: $6,000 in Black Satin, $6,100 in Black Gloss" yikes! :yikes:
How does the subwoofer law go? Optimize for LowFreq, size, or cost. Must pick at most two and give up on the other.
Wow, do know what kind of subs you could DIY for 6k!
For 12k on a subs you could get the TRW-17!
Matt
Keep us posted as to how the system sounds when you get it set up. Nice setup. Dennis
A TRW-17 looks awesome, but it would be impractical in most home theaters. Plus he would pay a small fortune flying the install team overseas to set it up. I personally think that 4 subs would be the way to go but I'm sure 2 JL 212's will be killer.
I agree that 4 subs would probably be better in most rooms. due to the smoothing effect multiple subs have on the Frequency Response. Wish I had 12k to spend on my whole theater let alone the sub!:unbelievable:
I have have quad Ultras and it is amazing for what it is worth.:hsd:
1 - 10 of 10 Posts
