1 - 7 of 7 Posts
So, I was noticing that my xbox isn't playing proper codecs on Blu-Rays. Is this something I did to settings? Or has it never played it properly.
When i play Akira with Tru-HD it says on the xbox that its playing Dolby Digital. On the Onkyo it says PCM. When I tried the supersonic codec on Akira, 192khz 24 Bit it didn't sound crazy(good) like the PS3 did and it still said Dolby Digital.
Xbox Settings are HDMI-5.1 Lossless. On Onkyo it is set to THX Cinema with Re-EQ turned off.
Sent from my iPhone using Tapatalk
Bit stream, it says pick Dolby Digital or DTS. Does it matter which?
Try both and see what the Onkyo says it's getting. Onkyo getting PCM means the xbox is decoding the HD audio, which you don't want.
Yeah. The bitstream does either and it forces it to either Dolby Digital only or DTS.
But i figured out half the problem... I was using the DVD instead of Blu-Ray. So half the problem fixed... sounds alot better. But the PS3 did alot better than the one in this aspect.
There is supposedly a big update coming soon that will enable Atmos on the xb1, maybe that will solve some of these issues?
I watch blurays on my bluray player and haven't tried on my xb1s yet so no issues here ;) UHD bluray on the other hand, I'm in a tight spot for audio tracks.
1 - 7 of 7 Posts
