1 - 20 of 28 Posts
Anything I can do to keep the room cooler without opening windows? If windows are opened I hear outside noises.. hoping someome can chime in who has remedied this situation
We watched our first movie the other night and I was surprised how warm our theater room got as well. I will be watching this thread.
Same here - HT gets warm after an hour or so. Problem is that almost any solution adds noise. Adding a second feed from the A/C will help but may not be easily done. Same for adding a return air line in the room.
I have a similar problem in my home office when the computers are on. I have looked at portable air conditioners, but they seem to have mixed reviews. A small window mounted A/C may work for both of us, but again, it adds noise.
I live in Texas and not having AC in a room really is not an option.
If the HVAC system has the capacity to handle another room (many/most don't) that's the way to go.
I have seen single room AC units that only have the condenser and fan unit in the room and the compressor mounts to the wall outside, the inside unit was mounted above a large sliding glass door and was much quieter than a window unit.
I dont have ac as an option.. so I was looking for other options like venting? Anyone have any luck with venting hot air out to keep room cooler?
One thing, the hi/lo bulb setting will help control this some. You all have probably already tweaked this to your liking, but running your PJ in Eco mode will help reduce heat.
Beyond adding more A/C, I guess you could always build your own fan driven venting system that picks up your PJs fan output and pulls it through some kind if flexible shaft, dumping it in another room. There are small quiet fans that could be added in to help pull the air. Probably wouldn't be too hard to implement.
We have no air conditioning. I run my projector for about 8 hours everyday to prolong the life of the bulbs (yearly replacement) and the room is usually not hot. Eventually I hope to be able to get a LED projector which should reduce heat to almost nothing plus eliminate the bulb changes and maybe reduce the electricity cost too. :)
Do you have a vent for projector?
Nope... I have my Epson 1080 resting on a shelf hanging from the ceiling. The shelf is about 2'x3' and hangs from threaded rod from the ceiling. It is open on all four sides so it has plenty of ventilation. It does not heat up the room. I run in eco mode only.
Mine is hanging from ceiling mount is ran in eco mode all the time as well.. ventilation all the way around and makes room hot because hot air has nowhere to escape in room
I have my room in the basement so it never gets warm but I would suggest running a vent to the exhaust side of the projector and suck the warm air out into another room with a fan.
So far my room is always super cold, but it's in the basement and has no door, and two HVAC vents. If you can get all the equipment other than the projector out of the room that will help, and just having a couple vents on opposite sides of the room from each other will promote airflow and help keep the temperature in line with the rest of the house.
I not everybody's equipment is as hot as mine. I have a launch Playstation 3 and it used to heat the living room in the winter. Although looking at your previous posts it looks like you have an Onkyo receiver, which generally put off some pretty serious heat too. It may not be enough to make the room uncomfortable on it's own, especially with it being further away from you than the projector, but if you want your room cooler, getting that receiver out of it will help.
What kind of room is it? Do you have some pictures, or a floorplan? Without any HVAC vents in the room, your best bet is likely going to be to have an exhaust vent up in the top of the wall to another room, near your projector, and an intake vent in the bottom of the wall on the other side of the room. If you have the space outside of the room you can add a quiet fan to the exhaust vent or both vents to help with the airflow.
The only thing better than that without tieing into an HVAC system would be a hush box with separate dedicated intake and exhaust channels.
Discussion Starter · #15 ·
I have 2 recievers.. the onkyo in livingroom is a 906 thats thw one that gets hot.. the one in bedroom is not causing heat issues the projector is.. ill post pics later. . I was thinking an exhaust vent I just wanted to make sure it helped before I did it
Getting airflow in there is the key. One vent for exhaust isn't going to do anything without another one for intake to allow the air to move. A really large vent could serve both purposes, like a louvered door, but unless it's really close to the projector it won't cycle enough of the room's air to make a difference.
Discussion Starter · #18 ·
Its grabbing air from the open room.. the projector isnt living in a air restricted enviroment.. its hanging from ceiling
A vent doesn't grab anything, it just provides a path for air to move through. Even if you have a fan on the vent, it's not going to keep sucking the hot air out of the room unless there's a way for cool air to come in to replace it. That's why you either need a really large vent that allows air to both enter and exit the room, (for example, just leaving the door of the room open) or you need a vent on one side of the room for air to enter and a vent on the other side of the room for air to exit. Having two vents far apart from each other is more efficient, because it makes it far less likely for hot air to exit the room only to come right back in again. The hot air will rise and move out of the room where there is less hot air, and movement of air out of the room will automatically cause air to be pulled in from the other vent. This process will become more controlled and even more efficient if you put a fan on the exhaust vent, forcing the airflow in the direction you want it to go.
Or maybe I misunderstood your statement. If you're just talking about the projector, yes, it's pulling air from the room. What it does next is use that air to cool down the projector, which heats up the air, and spits it back out into the room, continuously. If you don't have airflow in and out of the room, the projector will eventually heat all of the air in the room, which is what you are complaining about. If you allow the room to exchange air with the rest of the house, the projector will have much more air to work with.
1 - 20 of 28 Posts
