1 - 12 of 12 Posts
It could be that you have dynamic compression turned on in the DVD player or that your using night mode on the receiver.
the sound is fine but I can not hear the voices............i turn the nightmode off.........and the voice did not changed.............now when I am watching movies on dishnet work..........like the old terminator movies.......i tried to watch it in sorroundsounds and the voices were low..........had to turn the volume way up to hear.......what is wrong
Check to make sure that the level for the centre channel is high enough (in the setup speaker menu of the receiver).
How do you have the receiver connected from the DVD player and how do you have the display conected?
Ok, I think you may need to check that you dont have the audio out from the receiver enabled to the display as this may cause your audio to default to 2.1 channels rather than the full mix.
Ok, How do i check this??
should be a setting in the audio menu of the receiver (maybe under the HDMI out options).
No problem, Turn the HDMI audio out to "off" as this may be the reason your having the issue you describe above.
1 - 12 of 12 Posts
