1 - 20 of 33 Posts
Lumagen Radiance (XE/XE+/XE3D/XE/XE+/XE3D/Mini-3D/XD/XD3D) New 070114 Firmware Update
Release Notes
A couple of APL test pattern fixups.
Speeds up test patterns. (Update time ~3 minutes @57k)
Download Link
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 070114 Firmware Update
Release Notes
Adds capability (for 2041/2042) to Auto output selection to select 4K output modes when appropriate based on the displays 4K EDID information---works with 4K Sony projectors.
Fix for sometimes incorrectly disabling a video output when changing between sources. (Update time ~3 minutes @57k)
Download Link
Discussion Starter · #2 ·
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 070214 Firmware Update
Release Notes
Bugfix for issue that can blank output video to an output when switching memories in some cases. (Update time ~3 minutes @57k)
Download Link
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 070214 Firmware Update
Release Notes
Adds [email protected], [email protected], [email protected] output modes (2143/2144 only).
Adds capability (for 2143/2144) to Auto output selection to select 4K output modes when appropriate based on the displays 4K EDID information---works with 4K Sony projectors.
Slight improvement to 4k scaling.
Fixup for 2144 analog video input 9 not working after factory reset.
Bugfix for issue that can blank output video to an output when switching memories in some cases. (Update time ~15 minutes @57k)
Download Link
Lumagen Radiance (XE/XE+/XE3D/XE/XE+/XE3D/Mini-3D/XD/XD3D) New 070314 Firmware Update
Release Notes
Fix for issue with rs232 test pattern usage that would often give a corrupted picture. (Update time ~3 minutes @57k)
Download Link
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 070314 Firmware Update
Release Notes
Download Link
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 070314 Firmware Update
Release Notes
Download Link
Lumagen Radiance (XE/XE+/XE3D/XE/XE+/XE3D/Mini-3D/XD/XD3D) New 070414 Firmware Update
Release Notes
Another rs232 test pattern problem fixed.
An issue with screen being blank fixed.
Problem with using left arrow on remote for aspect changes fixed. (Update time ~3 minutes @57k)
Download Link
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 070414 Firmware Update
Release Notes
Download Link
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 070414 Firmware Update
Release Notes
Download Link
Lumagen Radiance (XE/XE+/XE3D/XE/XE+/XE3D/Mini-3D/XD/XD3D) New 070514 Firmware Update
Release Notes
One more fix for an issue with rs232 test pattern usage via calibration software. (Update time ~3 minutes @57k)
Download Link
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 070514 Firmware Update
Release Notes
Download Link
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 070514 Firmware Update
Release Notes
Download Link
Lumagen Radiance (XE/XE+/XE3D/XE/XE+/XE3D/Mini-3D/XD/XD3D) New 070714 Firmware Update
Release Notes
Found 2 other issues with rs232 test pattern usage via calibration software. (Update time ~3 minutes @57k)
Download Link
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 070714 Firmware Update
Release Notes
Fixed timing issue causing video corruption on output1 on some units. (Update time ~3 minutes @57k)
Download Link
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 070714 Firmware Update
Release Notes
Download Link
Lumagen Radiance (XE/XE+/XE3D/XE/XE+/XE3D/Mini-3D/XD/XD3D) New 070814 Firmware Update
Release Notes
A fix for exiting test patterns when using vertical shift (bottom of screen left uncleared). (Update time ~3 minutes @57k)
Download Link
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 070814 Firmware Update
Release Notes
Download Link
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 070814 Firmware Update
Release Notes
Download Link
Lumagen Radiance (XE/XE+/XE3D/XE/XE+/XE3D/Mini-3D/XD/XD3D) New 072014 Firmware Update
Release Notes
Small horizontal and vertical chroma improvements.
Added a CUE (chroma upsample error) setting under Input: Video Setup: RES: Picture.
Fixed an issue to handle 720p50 framepacked 3D source. (Update time ~9 minutes @57k)
Download Link
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 072014 Firmware Update
Release Notes
Fixed an issue that sometimes caused problems updating at 57k baud (so after this update is made subsequent updates should run smoothly at 57k). Preferable to perform this update at 28k to avoid problems. (Update time ~15 minutes @57k)
Download Link
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 072014 Firmware Update
Release Notes
Download Link
Lumagen Radiance (XE/XE+/XE3D/XE/XE+/XE3D/Mini-3D/XD/XD3D) New 072114 Firmware Update
Release Notes
Fixed an issue to handle 720p50 framepacked 3D source. (note: bug occurred in 072014 and this update replaces it) (Update time ~9 minutes @57k)
Download Link
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 072114 Firmware Update
Release Notes
Fixed an issue that sometimes caused problems updating at 57k baud (so after this update is made subsequent updates should run smoothly at 57k). Preferable to perform this update at 28k to avoid problems. (note: bug occurred in 072014 and this update replaces it) (Update time ~15 minutes @57k)
Download Link
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 072114 Firmware Update
Release Notes
Download Link
Lumagen Radiance (XE/XE+/XE3D/XE/XE+/XE3D/Mini-3D/XD/XD3D) New 072214 Firmware Update
Release Notes
A bugfix for CUE filtering from 072114 firmware when upscaling.
Improved the CUE filter menu, filter did not immediately turn on when enabled (Update time ~9 minutes @57k)
Download Link
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 072214 Firmware Update
Release Notes
Improved the CUE filter menu, filter did not immediately turn on when enabled.) (Update time ~15 minutes @57k)
Download Link
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 072214 Firmware Update
Release Notes
Improved the CUE filter menu, filter did not immediately turn on when enabled. (Update time ~3 minutes @57k)
Download Link
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 080114 Firmware Update
Release Notes
Fix for a configuration saving issue that didn't allow the "undo save" to work properly.
Also, another fix for working with the configuration utility.
Note the configuration utility was also just updated to version 1.8. as the earlier version was not downloading the CMS portion of the configuration to save on a PC for 21XX units. If you backed up your 21xx configuration earlier you should back it up again after performing this update and downloading the new 1.8 version of the configuration utility.
There were some improvements to the config utility as well. (Update time ~3 minutes @57k)
Download Link
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 081514 Firmware Update
Release Notes
Added 17x17x17 CMS (4.913 Color Points) along with corresponding menu and rs232 command options.
Added option to enable Darbee enhancement for just 2d or just 3d sources.
If you back up your setup to a PC Be sure to download the new configuration (v1.8) utility from the Lumagen Utilities page to use with your Radiance 21xx. (Update time ~15 minutes @57k)
Download Link
Lumagen Radiance (XE/XE+/XE3D/XE/XE+/XE3D/Mini-3D/XD/XD3D) New 081514 Firmware Update
Release Notes
Added faster serial port IO to enable faster operation with calibration software. (Update time ~3 minutes @57k)
Download Link
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 081514 Firmware Update
Release Notes
Added option to enable Darbee enhancement for just 2d or just 3d sources. (Update time ~3 minutes @57k)
Download Link
Discussion Starter · #14 ·
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 081614 Firmware Update
Release Notes
Added option to enable Darbee enhancement for just 2d or just 3d sources. (Update time ~15 minutes @57k)
Download Link
Discussion Starter · #15 ·
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 081714 Firmware Update
Release Notes
The audio configuration menu had lost the spdif/coax selectable options from 050114-081614 in 20xx models only. (Update time ~3 minutes @57k)
Download Link
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 081814 Firmware Update
Release Notes
Location values for 17x17x17 gamut adjustment via the menu were off by 1 for a few locations due to a rounding error. (Update time ~3 minutes @57k)
Download Link
Discussion Starter · #17 ·
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 081814 Firmware Update
Release Notes
Location values displayed for 9x9x9 gamut adjustment via the menu were off by 1 for a couple locations due to a rounding error. (Update time ~3 minutes @57k)
Download Link
Discussion Starter · #18 ·
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 082014 Firmware Update
Release Notes
Bugfix for configuring analog composite inputs (2143, 2144 only). The menu would show settings being made for these inputs without corresponding changes to the picture. (Update time ~3 minutes @57k)
Download Link
Discussion Starter · #19 ·
LightSpace CMS 6.6.3.1972 (12 September 2014) Closed Beta
Light Illussion has released a Closed Beta Version of LightSpace CMS that supports the Lumagen 21xx uploading of 17-Point Cube 3D LUT Tables.
Because I don't have a Lumagen 21xx here to test it, If any LightSpace user with Lumagen 21xx need to test it, I can provide him the download link via a simple PM.
Discussion Starter · #20 ·
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 091014 Firmware Update
Release Notes
Fix for a bug which under some circumstance could give strange colors in grayscale intermittently. (Update time ~15 minutes @57k)
Download Link
1 - 20 of 33 Posts
