21 - 33 of 33 Posts
Discussion Starter #21
Lumagen Radiance (XE/XE+/XE3D/XE/XE+/XE3D/Mini-3D/XD/XD3D) New 091114 Firmware Update
Release Notes
Fix for a bug which under rare circumstances could give strange colors in grayscale that a user may have remedied by turning off and back on. (Update time ~9 minutes @57k)
Download Link
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 091114 Firmware Update
Release Notes
Fix for a bug which under rare circumstances could give strange colors in grayscale that a user may have remedied by turning off and back on. (Update time ~15 minutes @57k)
Download Link
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 091114 Firmware Update
Release Notes
Fix for an issue that changes a 17x17x17 CMS to an 8 point CMS when copying from a CMS location to another. (Update time ~3 minutes @57k)
Download Link
Discussion Starter #22
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 091214 Firmware Update
Release Notes
Fix for an issue in 091114 having problems with 480/576p reinterlacing giving blank screen or green/pink colors.
Fix for an issue with the test pattern color when editing the color gamut via the menu. (Update time ~15 minutes @57k)
Download Link
Discussion Starter #23
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 100514 Firmware Update
Release Notes
Fix for not being able to power up on an analog input. This update is only helpful for units with analog inputs (2022/2042). (Update time ~3 minutes @57k)
Download Link
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 100514 Firmware Update
Release Notes
Fix for not correctly handling Pal (576i) video on analog inputs and not being able to power up on an analog input. This update is only helpful for units with analog inputs (2124/2144). (Update time ~3 minutes @57k)
Download Link
Discussion Starter #24
Lumagen Radiance (XE/XE+/XE3D/XE/XE+/XE3D/Mini-3D/XD/XD3D) New 103114 Firmware Update
Release Notes
Fix for output setup issue with being unable to select desired Style after being previously set.
Added 24 Hz to the direct vertical rate command ("menu 04"). (Update time ~3 minutes @57k)
Download Link
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 103114 Firmware Update
Release Notes
Fix for auto aspect when "Letterbox Zoom" was set to off and would do a zoom step for 2.40 and 1.85 sources.
Download Link
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 103114 Firmware Update
Release Notes
Fix for an issue with optional CRT 3D glasses emitter.
Fix for output setup issue with being unable to select desired Style.
Added 24 Hz to the direct vertical rate command ("menu 04"). (Update time ~15 minutes @57k)
Download Link
Discussion Starter #25
Lumagen Radiance 20XX Series (2020,2021, 2022, 2041, 2042) New 110114 Firmware Update
Release Notes
Fixed issue where setting hotplug to always on could result in video not turning on for output. (Update time ~3 minutes @57k)
Download Link
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 110114 Firmware Update
Release Notes
Download Link
Discussion Starter #26
Lumagen Radiance Configuration utility Version 1.81 for the Radiance XD/XE/XS/Mini/20XX/21XX
This is a PC windows application useful for several tasks:
Backup/restore your setup by downloading/uploading to your PC.
Share your configuration with other users or Lumagen to solve problems.
Download Link
Discussion Starter #27
Lumagen Radiance (XE/XE+/XE3D/XE/XE+/XE3D/Mini-3D/XD/XD3D) New 012515 Firmware Update
Release Notes
Fix for loss of video issues with chromebox and other HTPC type sources. Fix for constant height setup with certain 3D formats and scale bias off causing incorrect picture. Fix for test patterns with side-by-side or top-bottom 3D output. Expanded size limits for rs232 "ZY2" command to match onscreen menu limits. (Update time ~3 minutes @57k)
Download Link
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 012515 Firmware Update
Release Notes
Adds composite input option to 2022/2042 component inputs. Improvements to auto aspect detection. Added auto aspect detection capability to analog inputs (2022/2042). Fix for loss of video issues with chromebox and other HTPC type sources. Fix for constant height setup with certain 3D formats and scale bias off causing incorrect picture. Fix for test patterns with side-by-side or top-bottom 3D output. Expanded size limits for rs232 "ZY2" command to match onscreen menu limits. (Update time ~15 minutes @57k)
Download Link
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 012515 Firmware Update
Release Notes
Fix for an issue with factory reset after enabling 17x17x17 CMS that would give incorrect colors. Adds composite input option to 2124/2144 component inputs. Improvements to auto aspect detection. Added auto aspect detection capability to analog inputs (2124/2144). Fix for composite input with film mode selected. Fix for loss of video issues with chromebox and other HTPC type sources. Fix for constant height setup with certain 3D formats and scale bias off causing incorrect picture. Fix for test patterns with side-by-side or top-bottom 3D output. Expanded size limits for rs232 "ZY2" command to match onscreen menu limits. (Update time ~15 minutes @57k)
Download Link
Discussion Starter #28
Lumagen Radiance 20XX Series (2020,2021, 2022, 2041, 2042) New 030115 Firmware Update
Release Notes
Fix for test patterns with 3D signal and 2.35 output.
Fix for 2022/2042 analog component input when source switches from higher resolution to 480i and the 20XX loses the 480i picture. (Update time ~3 minutes @57k)
Download Link
Discussion Starter #29
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 080415 Firmware Update
Release Notes
Fix for problem with setting vertical shift greater than 0 when using output shrink (a combination sometimes used for setting up a 2.35 output aspect).
Fix for issues with not displaying video source correctly in a rare situation.
Improved reliability of output video connection.
Download Link
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 080415 Firmware Update
Release Notes
Download Link
Discussion Starter #30
Lumagen Radiance 20XX Series (2020, 2021, 2022, 2041, 2042) New 011216 Firmware Update
Release Notes
Adds rs232 input aspect query command, "ZQI20".
Adds rs232 full information query command, "ZQI21".
Adds rs232 command, "ZY550" to reset automatic aspect detection which is useful if user temporarily overrides it and then wants to re-detect automatically.
Adds "Full" option to reporting mode changes via rs232 in menu under "Other: I/O Setup: RS-232 Setup".
Fixes output aspect per input aspect problem with 2.40 input aspect using the 2.35 output aspect.
Adds improvements to automatic image based input aspect such that detection is more reliable and also will unzoom to display DVD setup menus, etc when they are detected.
If you need documentation on the new rs232 commands before our rs232 tech tip is updated please email us at [email protected] .
Download Link
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 011216 Firmware Update
Release Notes
Download Link
Discussion Starter #31
Lumagen Radiance 20XX Series (2020, 2021, 2022, 2041, 2042) New 011316 Firmware Update
Release Notes
The newly added ZY550 rs232 command wasn't working too well and was fixed.
The ZQI21 command returned incorrect vres for 4K output modes.
If you aren't using these rs232 commands then you do not need to update.
Download Link
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 011316 Firmware Update
Release Notes
Download Link
Discussion Starter #32
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 100516 Firmware Update
Release Notes
Small improvements from Radiance Pro auto image aspect detection were added.
Download Link
Discussion Starter #33
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 030517 Firmware Update
Release Notes
For 21X4 adds PC/Video level setting for composite and s-video sources. Adds audio mute delay for analog video sources.
Download Link
21 - 33 of 33 Posts
